AVS › AVS Forum › A/V Control & Automation › Home Automation › Any Way to Make Lutron RadioRA2 Work With RadioRA?
post #1 of 2
I have a RadioRA setup in my home, with a few dozen dozen components. I like some of the new features with RadioRA2 and would like to add some of those features to my system, but I do not want to remove my existing RadioRA components.
Is there any way to make a RadioRA2 device work with a RadioRA device, such as a repeater that changes frequency/signal? Note that I do most of my lighting/scene changes using a URC MX-900 remote via a RA-IR, rather than wall/table controllers. Perhaps a URC remote macro could contain one step that changes lighting for RadioRA devices (via RA-IR) and another step that changes lighting for RadioRA2 devices (via equivalent product for RA2)?
post #2 of 2
From what I was told in a Lutron class, the 2 are incompatible. You would have to completely replace your system with the Ra2 system.
  Back to Forum: Home Automation
