Has anyone had any problems with their Ceton card resetting itself every few days? I leave my computer on 24x7 and the longest time my card has been up is about 6 days. I'm not able to trigger a reset but it usually happens after 2 or 3 days. All tuners are unavailable for about 1 min 30 seconds while the card resets.
If you go to the System tab on the Ceton web interface, there's an Uptime field. Uptime is then reset to 0 after this happens. Does this happen to anyone else who leaves their computer on 24x7?
My setup is fairly simple and here's what's been done so far to troubleshoot:
- Cablecard replaced
- Switched cable providers (from Cablevision to Fios) - low pass filter is installed
- Ceton sent a replacement card but the problem still happens
- Ceton had me try the latest beta firmware
- Disabled network tuner support
- Ceton temps usually around 55
I'm running on an AMD x2 3600+ w/ Windows 7 Professional x64 and 8GB RAM. Any feedback or assistance is appreciated -- Ceton support seems to have forgotten about me. Let me know if you'd like more details on my configuration.
Mike
Mike
