AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › How to mount DIY frame to wall?
post #1 of 9
I need to mount my screen frame to the screen wall. It is MDF wrapped with velvet. The two options I can think of are velcro, or finishing nails through the velvet/MDF into the drywall.
LMK what you think.
post #2 of 9
You could also hang it like a picture frame. The problem with nails is when you want to take it down. You may damage the drywall trying to pry it off.
post #3 of 9
Pieces of wood cut on an angle to form a cleat will work. google French Cleat
post #4 of 9
I don't think I need something as substantial as a french cleat. The frame sections are separate, and weigh about a pound or two each, max. I don't really care about nail holes, if the frame comes down one day, the wall will need a repaint anyways. I'm leaning towards small finishing nails.
post #5 of 9
Then this is MDF with which I am unfamiliar!
If you do decide to use finishing nails, by all means do not place your hamster's cage or fish bowl anywhere under your screen.
post #6 of 9
Maybe MDF is the wrong term. The stuff is the white baseboard material you get from HD. It's like it is made out of recycled cardboard, with a white finish on the front. It is really light.
post #7 of 9
yes that's called mdf baseboard. or medium density fiberboard.
post #8 of 9
I do as well...and I lean into them with a Hammer, and then "set" them deeper into the MDF (...and thus "under the surface of the Velvet...) using a Nail Set.
Another neat trick to employ so you cannot ever see the Nail heads is to hammer them in at a slight angle....always "away" from the inside edge of the Trim/Screen.
post #9 of 9
I second a french cleat. It is easy and secure. Only need two holes. Understand that the cleat itself doesn't have to be more than nine inches.
  Back to Forum: DIY Screen Section
