Originally Posted by kbarnes701
The mic connects to the preamp and the preamp connects to the PC Left input on the rear of the unit. If access to the rear of the unit is a PITA, as it is for me, you may consider leaving the cable permanently attached to the PC Left input to make it easier to run Pro again (I guarantee you will run it more than once).
Although the Pro software can connect to the 80.3 over a wireless connection, it is recommended to use an Ethernet cable, so you may wish to consider leaving that in place too. The other end of the Ethernet cable connects to a router. It doesn't have to be the router you normally use for your home network. In my case, my network router is nowhere near where the AVP is, so I use a spare router I had in my junk drawer. The Integra connects to the router, the router connects to the laptop. If you do it this way, you can also leave the router permanently in place if you wish. You will need to go into the Integra Network menu settings to see what IP address the router is using - you will then need to enter that in the Pro software when asked. It all sounds complicated but once you have done it, it's pretty straightforward and obvious.
I think it was pepar who alerted us to the fact that you do not need a router or hub. You can connect Ethernet from a PC directly to the prepro with nothing in between. Apparently, it is self inverting. I just tried this last week and it works like a charm. Glad I paid attention!
Of course, you can do it via a network as well. But, best to have the PC close to the listening room because each new mike position sweep will require hitting a soft button in Pro to start it.
. Thanks for telling which input the mic preamp plugs in! So PC input and left channel on the back. I will end up leaving the cable there too as I know I will be running a few cals.
I think you are right on the money when you say "always assume it won't and measure/fix accordingly.". That way we are more certain. Trust but verify
