Originally Posted by AustinJerry
I have a slightly different perspective. When I run a Pro calibration, my sub distances always come up slightly different, even though I carefully use the same measurement positions. The differences are small, usually less than .5 ft. Also, I am in the habit of always re-checking the sub distance tweaks after a new calibration. When the Audyssey-calculated sub distances are slightly different, I find that the optimum distance tweak changes slightly as well.
So, the point I am trying to make is, unless you re-measured with OM after the recent calibration, you can't be absolutely sure that your sub distances are indeed still optimized. I would hope this were the case, rather than believe that Audyssey "gets it right" sometimes, and not others.
I dunno, Jerry. I will always use OM now, as you suggest, after a calibration to check the sub distances and see if I can improve the graph. Trust but verify.
