AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Audyssey Pro Installer Kit Thread (FAQ in post #1)
The Audyssey Pro Installer Kit Thread (FAQ in post #1) - Page 101
post #3001 of 4427
Originally Posted by pepar View Post
Thanks, Amir. Audyssey graphs, both consumer and Pro, are ... not useful. And the "after" isn't really even "after." It is "before" with calculations. Querying that, we get "linear systems theory" as part of the answer. Maybe so, but I don't think that instilled confidence in anyone that we were looking at what we were hearing. Plus, proprietary secret sauce is used, so even if we could use REW to measure in identical locations, we still wouldn't know how to weight the results. Fortunately, the results are usually so darn spectacular that we grouse about it and then sit down and enjoy our systems.
I doubt that we will ever get the detail ... or the realtime results ... that Synthesis offers. Fortunately, the results with Audyssey are usually so darn spectacular .... smile.gif
Jeff
+1 to all you said Jeff.
Meantime, while since REW was mentioned here, amid all the bells and whistles it has a neat little Generator that can be easily used to let us hear what we will hear.
As a starting point to verify the bass department select Log Sweep, Start: 10 Hz, End. 200 Hz, Duration: 60 sec (slow enough for a careful listening), Level: to taste:
I believe we are all able to spot variances in level (or call it loudness) while the sweep slowly advances. When I followed Mark Seaton's and Craig John's method of sub distance adjustment to flatten out the crossover splice, I used this method to cross check the results BY EAR!!!. After a bit of iteration of the original sub distance set by Audyssey I could clearly hear a smooth (read: constant level) of the test sweep as it went through the crossover region (in my case at around 80 Hz). With the original Audyssey sub distance there was an audible level drop definitely detectable by ear.
post #3002 of 4427
post #3003 of 4427
As you say Jeff. "almost". Raw material good, but putting a little spice on the splice makes it's taste to be "oh-la-la"! wink.gif
post #3004 of 4427
I'm glad you were able to improve upon already very good results.
Jeff
post #3005 of 4427
Keith,
I PM'd you some copy on the above. It really gets into he weeds and makes for a long-winded answer. If it seems too long, perhaps the "answer" should route them here for in depth instructions?
I dunno.
Jeff
Got it - thanks Jeff. A great start for the answer to that question.
post #3006 of 4427
I just got some asume new FR/L speakers (Euphonia MS5!!!) so I downloaded and ran Pro Ver 3.6 yesterday.
< edit: the following statement turned out to be optimistic and incorrect, there's no change from the prior FW version:->
It appears to me that for the A100 they have addressed (if not fixed) the problem of not treating the Sub 1 and Sub2 individually irt to distance and levels.
Prior to running Pro, I did a quick MultEQXT32 (no Pro) cal:
Sub 1 dist 15.6' level +3
Sub 2 dist 6.9' level +2.5
The above non-Pro distances accurately reflect the subs have a 9' delta in distance to MLP. These are identical subs and neither is doing any additional internal processing.
I adjusted each sub's internal vol down <<edit>> oops, UP a smidge and ran Pro. Results:
Sub 1 dist 15.8' level -1
Sub 2 dist 14.9' level -1.5
I did a few Stereo music listening tests (no measurements and no LFE involved). With xovers set to 80 and the Pro distance settings the bass SQ is really great. I tried resetting the sub 2 distance down to 6.9 and that seems to lessen the bass slightly on bass-laden passages. Based on some crude prior measurements (1/5 smoothing in the Velodyne SMS system), varying the sub distance made little difference. It could be that 6.9 is flatter (could be in effect lessening a peak or two I have below 80). But I reset it back to 14.9 for now.
I've never owned anything quite like these #175 each, $16K/pr MSRP 3 ways sporting 2X 8" woofers, a mid and two tweeters (dome plus ribbon) top-of-the-line Dali speakers.biggrin.gif So I had to try the top-ranked-by-Pro Large setting (of course sub set to LFE only in the AVR so no double bass). Wow, nice bass! Very impactful, and very well-imaged and nuanced/detailed.
Of course I also tried setting front speakers to Small and varying the crossovers on FR/L as they were ordered from Large to 40 to 80. Again no measurements, but that seemed to result in a progressive slight lessening of the bass. That may be due to a flatter room response from the advantageous opposite mid-wall placement of the subs. But as to my preference, the recording itself actually matters far more than the Lg vs Small w/xover 40 vs 80. A recording that I would've mixed with a bit more bass sounds a bit better on Large, a recording that I would've mixed with less sounds a bit better with xover=80. With any choice, the SQ with Pro is simply gorgeous. biggrin.gif
So I left it at Small/ xover=80. Some quick listening tests to MC music: Ahh, amazing SQ! Of course the matching Euphonia Center Channel I got with the speakers is a perfect match.
I spent nearly all day on this so further experiments (maybe rerun Pro?) will have to wait. I can't account for why Pro set the sub 2 distance to what it did.
Edited by SoundofMind - 9/29/12 at 3:33am
post #3007 of 4427
I adjusted each sub's internal vol down a smidge and ran Pro. Results:
Congratulations on the fine new speakers!
WRT the Pro issue of setting the two subs to the same distance and trim level, the issue manifests itself only when you reload a previously-save measurment file and re-calculate the filters (e.g. if you are trying different crossover values).  It's not clear from your post, were you changing the crossovers in Pro and re-calculating?  If yes, then the bug indeed seems to be fixed.
It is indeed peculiar that the Pro and non-Pro distances for Sub 2 are so different.  Also, if you adjusted the sub gain lower, why were the resulting Pro trims lower as well?  Once would expect a higher value, no?
post #3008 of 4427
^Thnx for the complement, they are awesome, he-he.
Good points. I did not reload or recalc anything in Pro. As we've been informed that the filters are not calculated specifically for the xover chosen in Pro, AFAIK there's no point in doing that. Edit: well there is a point, see AustinJerry's response below
I believe I've posted that in the past, IIRC, Pro never handled my two subs differently, even first time thru a cal regardless of no reload. But I'm too busy today to search and verify that. So anyway, I thought maybe this Pro vers. handled it differently.
You are of course correct on the sub vol thing, that's my reporting error and I'll correct it. I lowered the sub vols just prior to the initial XT32-only autosetup to get the new baseline, having moved MLP slightly. I'd forgotten that to get more signal to keep my subs awake, I'd already turned the subs vol down months ago (and I'd then compensated to get back to reference and more juice by trimming each sub ch up in the AVR). As level 3 was too low and giving pos trims, I raised them to 4 prior to running Pro.
Only other factor irt distance I can think of offhand was a "subs may be out of phase" error in Pro which I ignored, as I had in the past per Luke's recommendation.
If I had more time, I'd get me an OmniMic or REW to get some more accurate data....
Edited by SoundofMind - 9/18/12 at 4:23pm
post #3009 of 4427
That's not been my experience, Jerry. I find that Sub 2 is never set properly and is usually just set to whatever it was before - even on a new calibration (I have never reloaded an old cal). There is clearly an issue with it because the report only shows a result for one sub and IIRC it has the distance set for Sub1 and the level set for sub 2 (as confirmed by the AVP screens).
SoM's dilemma is does he trust the XT32 measurement or the Pro measurement for Sub 2. My inclination would be to trust the XT32 one. Best solution is to do the sub distance adjustment trick with independent measuring gear anyway IME.
post #3010 of 4427
Pro Kit FAQ section
Questions I have identified so far, not in their final order:
j)1.    What is the Audyssey Pro Installer Kit?
j)2.    What does it cost & where do I buy the Pro Kit?
j)3.    What are the differences between the Pro Kit and regular MultEQ?
j)4.    How do I edit the target curve, and why would I want to?
j)5.    What is the latest release of Pro software and where can I download it?
j)6.    What are the 'Target Sound Options'?
j)7.    How do I connect the kit to my AVR or AVP?
j)8.    How do I get started?
j)9.    How do I save my measurements for future use?
j)10.  Are there any known issues/bugs in the Pro software?
j)11.  What is the latest version of the Pro software and where do I get it?
j12)   Can I use the Pro Kit to help set up my system prior to calibration?
j13)   Do the results from the Pro Kit depend on the AVR's 'base' version of Audyssey?
Anyone got any more please?  Comments welcome of course. I shall start writing these soon.
SoM - congrats on the new speakers. Please confirm you have no problem* with my adding the Pro Kit stuff to the FAQ, based mainly on posts in your Pro thread. Thx. Each FAQ answer will contain a link directing readers to your thread.
* Or of course, please say if you do!
post #3011 of 4427
What avr, pre pros are "Pro" capable?
post #3012 of 4427
^Thnx Keith. I spent the whole weekend getting the speakers and setting them up. This included some toe-in experiments I will report on later. Then I spent most of yesterday preparing for and doing calibration. Exhausting but the results are SO worth it.smile.gif
So I haven't gotten the chance to even thank you for your fab wotk on the Pro FAQ (much less read it redface.gif ). It's cool that you're building on your amazing work on the Audyssey FAQ!
You are very considerate to ask, and of course you have my whole-hearted support to use anything from this thread. It's actually not my thread but rather more of a co-op ownership amongst all the valued contributors. wink.gif
(But regardless I may just leave this thread in my will to whomever sucks up to me the most). biggrin.gif
post #3013 of 4427
Reordering them ..
j)3. What are the differences between the Pro Kit and the Audyssey version that's built into my unit?
j13) Do the results from the Pro Kit depend on the Audyssey version that's built into my unit?
post #3014 of 4427
IIRC, you are the only one who has reported this particular behavior, Keith. Very odd indeed, because I have never had an issue with Sub2 on the first calculation, only on a re-load.
post #3015 of 4427
Good one. Added. Thanks.
post #3016 of 4427
LOL. Thanks SoM.
Yes, a lot of effort to get new speakers 'just so' but well worth it as you say. Be interested in further reports...
The Pro FAQ section should be ready early next week for Jerry (who has kindly offered to fact-check it for me) and incorporated into the FAQ by the end of next week. Hopefully.
Although I still have my new pattern generator and the brand new Calman 5 software to play with yet.... another steep learning curve I bet ;)
post #3017 of 4427
Reordering them ..
Much better. Thanks Jeff...
Keep 'em coming, guys...
post #3018 of 4427
Yes you are correct. It may be Onkyo specific or 5509 specific of course. I'm the only one here regularly who has a 5509 (mainly due to them not being sold in the US!). But I can repeat it every time. It's no big deal because I adjust my sub distances manually with OmniMic after the cal anyway.
And of course, SoM is now reporting a sub 2 anomaly on a new cal...
post #3019 of 4427
Reordering them ..
Keith--what about covering independent verification of Audyssey calibration, at least for addressing < 200 Hz sub EQ, as an 'advanced' topic? Some guidance for calibration learners about curve smoothing settings (understanding that there's some difference of opinion here about what's sensitive enough) and suggested AVR surround settings might be useful, at the very least, so that they don't have to hunt through multiple threads.
post #3020 of 4427
It has always worked for me on new calibrations where I use the level matching screen.
post #3021 of 4427
SoM,
Regarding not re-loading the measurement file when selecting different crossovers, this is not exactly correct.  According to the recent discussion with Chris on Ask Audyssey (with Markus), Chris acknowledged that the filters are not recalculated, but that a different value for the high-pass filter was being applied.  Chris' words:
"Yes, Pro applies the HP filter before loading on the AVR. That's why you need to go back to that page and make the change if you decide to use a different frequency for the crossover.
This HP filter is also applied in the consumer version. Keep in mind that it's a highpass filter applied to the filter and not to the signal. It's applied to "prepare" the response for the crossover filters that will be applied outside of Audyssey."
The entire thread is here:  Does MultEQ optimize the crossover region between satellite speakers and subwoofer?.
So, if you are changing the crossovers without re-loading the measurement file in Pro, there might still be some room for improvement for your new speakers...   :)
@Keith:  as soon as we get this sorted out, and there is agreement, this could be a useful item in the FAQ.
post #3022 of 4427
^Thnx for reminding me (and the rest of us) of that clarification by Chris. He says "you must" so it seems pretty important but I don't understand what he's saying. Apparently it's above my LPF. I'll edit my post as to not confuse others.
I'd told Pro to use 80 for all. In my later A/B/C/D listening tests I was completely focused on the bass and I heard only minor differences as described. Presciently, at the end of the day I reset all speakers to Small/80.
post #3023 of 4427
Reordering them ..
Sure thing - but someone will need to give me a little assistance on those topics as I am not confident enough to write them myself in an authoritative manner.
post #3024 of 4427
MultEQ corrects for the common crossover slope mismatch error by imposing a HPF to the speaker filter:
post #3025 of 4427
Then it has to be an issue with the 5509.
But it's still the case that the software reports it wrongly in the certificate. For a start it only graphs what it calls the 'Main Subwoofer' which is odd when you have two subs, albeit EQ'd as one - but if you look at the text underneath the graph it gives the distance and trim (why just one figure for each when you have two subs is the obvious question?) - what it gives me here is the distance for Sub 1 (as verified in the 5509 menus) and the trim for Sub 2. IOW, it's hopeless. Do you not get the same for distance and trim?
post #3026 of 4427
SoM,
You’re not kidding!  I'd like to see the definitive answer in one easily-accessible place!
post #3027 of 4427
Stuart, if you are talking about the process of adjusting sub distances post-calibration to improve the crossover splice, I'm not sure this belongs in a Pro-specific FAQ.  The same process could be applied after a non-Pro calibration.  I agree that a write-up on the theory, and how to do it, would be useful--I'm just questioning whether it belongs in the Pro FAQ.
Same goes for curve-smoothing recommendations.  Adjusting smoothing settings is not a feature of Pro.
And I'm not sure what you mean by the third recommendation, i.e. the AVR suggested surround settings.  Can you elaborate WRT what you are recommending?
post #3028 of 4427
Yes, I think we mentioned this before. It's not really relevant to Pro as such but it's too advanced for the general FAQ. I could include it in the Pro FAQ which, by definition and design, will be more for the advanced user anyway.
post #3029 of 4427
Yes, I recall that conversation.  IMHO, we need to approach this in steps, the first one being a conprehensive FAQ covering the advantages and operational differences of the Pro kit.  Once that is nailed down, I think there is another whole area that we could address as a team, and that is "Pre-calibration optimimization and post-calibration results assessment/adjustments" (hopefully we can find a less awkward title).
Perhaps I have too much time on my hands?
post #3030 of 4427
No, you're just very thorough:). And whether it belongs in a Pro FAQ as such, it's something that should be addressed as a team because we may have divergent opinions about where this might go. In your own words, we're in "uncharted waters" IIRC;).
To your point: my initial thought was that addressing post-calibration results assessment/adjustment, while not strictly related to Pro per se, is something that is a) more advanced than the average consumer Audyssey calibrator may be familiar with, particularly someone coming from an older Audyssey and/or non-Audssey AVR and b) a logical "next step" on the learning curve for the user seeking to optmize their system.
Not only does Pro offer up to 32 measurement positions, but the Target Curve Editor, choice of crossovers, save/load of measurements (imperfect as it is, as we know, WRT subs), choice of mid-range compensation curves etc. are part of the package. A user looking for those features is much more likely to want to further tweak their system than a "set and forget" person working with the conventional/consumer Audyssey release. Hence an "advanced" FAQ is a more appropriate place to have a pre/post-calibration optimization and assessment thread than an FAQ that's a "how to" for someone learning how to use Audyssey in the first place.
And by tweaking, I mean a combination of Target Curve editing, distance/delay/phase adjustments at the crossover/splice region, exploration of crossovers, repositioning of speakers, all accompanied by remeasurement as as I think we can agree that the "After" Audyssey charts are too coarse at 1/6 smoothing to be useful.
Hence having a flow chart of how to proceed, and understanding the issues involved in using a particular level of smoothing, is essential for the learning using Pro.
Also, I was thinking of my own experience in the past four months. Once ccotenj pushed me into the measurement rabbithole eek.gif, I found myself going through at least four different threads (here, Audyssey, OmniMic, and the 4311) to wrap my head around the most rigorous way to "trust but verify". Frankly, I would have been lost without Keith's trek in finding his phase issue to point the way. So collect another debt of thanks, Keith:D
Thinking about what speakers & sub combination to test, distance and/or phase adustments, what smoothing level, the kind of pseudo-noise signals and channels to use, and what AVR surround setting (I originally used Multichannel Stereo and PLII Music because I thought they were most appropriate for my listening, before I realized that Stereo and in some cases PLII Cinema were better options) took many hours that would have been shortened if we had a comprehensive assessment FAQ. I hope that others here, as well as newbies coming to the Pro thread as the 4520 and newer AVRs hit the market, could make use of it as well.
That's a long winded way of saying that not everyone has the level of intuition and experience, hence it has value...but regardless of whether we do it now or in the future, I'm glad we can at least put it on the agenda.
