AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Audyssey Pro Installer Kit Thread (FAQ in post #1)
The Audyssey Pro Installer Kit Thread (FAQ in post #1) - Page 120
post #3571 of 4228
Originally Posted by fitzcaraldo215 View Post
Many here seem to assume that the independent measurements are right and Audyssey is therefore wrong. Is that really true when weighted by psychoacoustic perception? But, it does not help matters that the graphs obscure certain details. However, the greater precision of independent measurements does not in all cases equate with greater accuracy of the perceived result.
Hi Fitz - I don't think, when I measure independently with OmniMic, that I am 'questioning' the Audyssey results and I am definitely not trying to reproduce them. The value of my independent measuring is that it lets me improve on Audyssey's automated results by showing me the actual post-calibration responses in my room. A couple of examples of this are the way that I managed, along with OmniMic, to tweak the sub distance and remove a big dip around the XO frequency and the way that the Target Curve Editor allowed me to make a couple of small adjustments that flattened the Audyssey-set response even more.
post #3572 of 4228
Originally Posted by sdrucker View Post
Question for the thread: is there a more detailed report of how Audyssey works than
http://ee.usc.edu/assets/005/56551.pdf
I understand fuzzy clustering (put 'simply', a form of dimension reduction of the measurement 'objects' with overlapping centroids), but there's no other real information except results here.
Also, if I read these graphs correctly, at least with MultiEQ, they're showing quite a bit of 'improvement' in higher frequencies. I agree that LF below 200 Hz is more critical, but practically, can XT32 improve higher frequencies _less_ than previous versions of Audyssey? I would think not, but has anyone done independent measurement of XT vs. XT32 to find out?
I do not know of any reason to believe that XT/32 is not better than XT in the highs. Usually, not nearly as much correction is necessary there, and unless your speakers are peaky, issues tend to be more broadband. Whatever the case, XT/32's enhanced filter resolution should, if anything, do an even better job there than XT. I hear no issues whatsoever with its correction in the mids and highs, though XT did do a nice job with them when I was using that. Personally, in my system, although room modes are the biggest problem, I also think that what Audyssey does in the mids and highs is quite important
post #3573 of 4228
Earlier this year, there was a lengthy discussion on the difference between XT and XT32. Measurements of the pre-out signals clearly showed a shift in focus between the two technologies. XT expended a lot more effort on the higher frequencies. XT32 paid less attention to the higher frequencies, and focused more of its correction power on the lower frequencies. At the time, there was a consensus that this shift was a positive change.
post #3574 of 4228
It is perhaps possible under some circumstances to further improve on what Audyssey does. I agree that particularly with multiple subs, which I do not have and do not feel the need for, independent measurements may be quite necessary. Also, the Seaton sub distance tweak, which makes logical sense to me, really requires independent measurements. But, I am not convinced that all independent measurements necessarily lead to better sound. I am an agnostic on that point, particularly given the differences in spatial averaging techniques, time windowing, frequency smoothing, etc. that occur between Audyssey and independent measurement protocols. I tend to put my faith more in the research that Audyssey has done in the many choices that have made in the approach that they provide. It may be blind faith, because I do not know any better than anyone all that is in their secret and proprietary techniques.
Underlying this is an understanding that room acoustics coupled with perceptual psychoacoustics is mind bogglingly complex. Audyssey has drastically simplified the correction process for us by incorporating all that into their very competent, if still imperfect, product. I am just not sure that a lot of extra work in independent measurements by a lay person like me is necessarily going to lead to a better result in terms of perceived sonics. It might lead to a different result, but I might be biased by all the work I have done into only believing it is better. For example, I know plenty of audiophiles, dealers as well, who believed that throwing a lot of room treatments at the problem was going to make the sound better. They thought so, but, in many cases, I, independently, really did not think so.
Audio always involves a tricky balance between measurement and subjective, perceptual assessment. I do not think that either alone gives the complete picture and either might be biased by a whole lot of factors.
post #3575 of 4228
Anybody try the new verizon to see if the bugs listed in this blog have been addressed?
post #3576 of 4228
Sorry
New version not verizon.
post #3577 of 4228
I remember that - and no question you're right as a generality of the relative processing applied. But what I'm wondering about is the results....is there any degredation of correction of the higher frequencies for XT32 relative to XT? I agree that I'd rather have better equalization of the subs and lower frequencies than the higher if that were the tradeoff that had to be made. However, did anyone quantify what this means at, say, 1/6th smoothing? That is, as an A/B/X test, does XT32 correct less from 300 Hz to 15 kHz, assuming other features are held constant (i.e. the same speaker configuration and room)? I don't have an XT receiver, of course, but I'm thinking (hoping?) that someone did this test at some point. I went from a Pioneer to XT32, so I have no idea what XT was like vs. XT32 personally.
If this is opening the sarcophagus, well, I saw the degree of improvement in the higher frequencies in the PDF I'd referenced, so it got me thinking. I'm expecting that XT32 would 'beat' XT across the board, but since we've occasionally disproved conventional wisdom...eek.gif
Edit: I still have my old Pioneer SC-27 and an AS-EQ1 on the island of misfit toys (the latter because I naively didn't save the box and packing stuff or the rack ears, figuring I'd never need them two years ago, so selling the lot might be an issue). One day I may get around to doing the MCACC+bass EQ vs. XT32 test, but that's about 70th on the priority list right now.
Edited by sdrucker - 12/19/12 at 4:42pm
post #3578 of 4228
^I recall the discussions on the Audyssey thread and some posted graphs. I myself heard the clear (pun intended) improvements of XT32 over XT in the HF detail and attributed it to XT32
1. wisely not "messing" with the highs as much as XT (pretty evident from the graphs) and
2. when intervening with the highs, doing so more accurately and judiciously (no data, just slightly informed guessing/wishful thinking) smile.gif
post #3579 of 4228
Reposted from the 8801 Owner's thread ...
Originally Posted by thrang View Post
Early Christmas card - got an email from audyssey that the Pro version has been updated today to support the 8801 and to fix the slow serial speeds for 4520 owners...
post #3580 of 4228
I expect as much too..but the USC presentation and some of the discussion we've had about the Curve Editor got me thinking...thinking can be a dangerous thing, of course:D
Bottom line is that I think you're right, but just wondering if it's actually ever been tested. Wonder if anyone has the graphs....it's the kind of thing Keith or AustinJerry would do for kicks......
Edit: wonder if this could be 'approximated' by doing a Pro XT32 run with just satellites (for laughs, I can run my Mythos powered mains + center as full range) and comparing to my normal XT32 Pro run with dual subs and my powered mains. Again, I'd only be interested in mid and higher frequencies. Assuming it's not a fool's errand, that is....if it is, that's worth knowing too...
Sorry, I'm in a heretical mood...or channeling my inner Scrooge McDuck tongue.gif
Edited by sdrucker - 12/19/12 at 5:58pm
post #3581 of 4228
Apparently, they are able to say this now ...
post #3582 of 4228
OK, now I need to get sold on the 4520 LOL....
post #3583 of 4228
p
My reputation is intact. When I upgraded to the 4520, I moved my 4311 to the bedroom system, displacing a 4308, which I subsequently sold. Being always curious about the differences between XT and XT32, I conducted a test as part of the upgrade process. I ran a special 8-position Pro calibration in my living room using the 4311. I then unplugged the 4311, and replaced it with the 4308, and ran a second 8-position calibration, using the same 8 measurement spots that I used with the 4311 (I mark my spots with those little red adhesive dots on the floor). Since all other things were constant, I claim this is as close to a scientific comparison as I can accomplish. For each calibration, I measured the signal from the AVR pre-outs, which is the accepted way of observing what Audyssey is doing to the signal.
I had originally planned to publish the results but, since we had already had a discussion earlier, I figured my report would be redundant. I still have the measurement data and, if you think it would be interesting, I would be happy to dust it off and publish it here. Is it worth the effort?
post #3584 of 4228
I am excited about the fix for the 4520 serial transfer rates. I intend to test this out tonight or tomorrow to verify the issue has been resolved, and I'll post my results.
post #3585 of 4228
I'd say yes...at worst, it confirms conventional wisdom and SOM's instincts, and further demonstrates the overall superiority of XT32. And if you find a difference, documenting where it occurs is useful not only to issues of placement and listening axis, but is something that Audyssey may want to comment on.
Is it a priority over a new run with the 3.6 upgrade? YMMV...
Edit: I asked the oracle on Audyssey's FB page, and his response:
There is no tradeoff. XT32 uses a more advanced method for correcting the high frequencies than XT. It involves smoothing to avoid going after narrow (inaudible) peaks and dips.
Edited by sdrucker - 12/19/12 at 7:47pm
post #3586 of 4228
Good news!
I have tested the serial transfer rates, and the slow transfer rate is indeed resolved.  I am now measuring a transfer rate that is actually marginally faster than the 4311.  An 8-position calibration for a full 11.1 configuration now will take 58 minutes, versus a full 60 minutes for the 4311.
Needless to say, for 4520 owners, this is huge.  I'll report my results to Audyssey and close the case.
post #3587 of 4228
Good news!
Congrats, Jerry! Your persistence has finally paid off. IIRC, Audyssey initially blamed Denon for the bug and then later, Denon blamed Audyssey.
Mark
post #3588 of 4228
Good news!
Mark
post #3589 of 4228
Mark
I'm going to try and find out what the root cause was.  I'm not sure either Denon or Audyssey will be forthcoming with this information, but we'll see.
post #3590 of 4228
Mark
Virtual hi-five to Jerry......
FWIW, I'm doing a fresh Pro Cal on the 4311 with the new software on Friday afternoon due to a speaker reposition. I'm home alone over the weekend, and the odds of a sudden case of the flu are about 100%... smile.gif
Edited by sdrucker - 12/19/12 at 8:28pm
post #3591 of 4228
Here is my analysis of an XT vs XT32 Pro calibration.
The test:
- Denon 4308 with MultEQ XT
- Denon 4311 with MultEQ XT32
- 8-position Pro calibration, using the same 8 positions for each AVR
- Test done on same day, with no other changes to the equipment, room, treatments, etc.
- Measurements taken for left, center and right channel from the AVR pre-out connections.
- In-room frequency response measurements using REW and EMM-6 calibrated mic, from same positions as the Audyssey calibration.
Left channel pre-out (no smoothing, blue is XT red is XT32):
700
Right channel pre-out (no smoothing):
700
Center channel pre-out (no smoothing):
700
In-room frequency response using REW (bass frequencies, no smoothing):
700
In-room frequency response using REW (10-20,000Hz, 1/6 smoothing)
700
My thoughts:  the pre-out measurement support the hypothesis that XT focuses more on the high end, while XT32 focuses on the low end.  And looking at the in-room measurements, one might conclude that XT32 is doing a better overall job in smoothing my room's response.
Comments?
post #3592 of 4228
The test:
700
700
700
700
700
Comments?
I couldn't agree more. And it confirms what Chris said on FB.
post #3593 of 4228
Who do I send my consulting bill to?
Edit:  BTW, I owe a debt of gratitude to Markus767, who assisted me in making these measurements.
post #3594 of 4228
post #3595 of 4228
The test:
700
700
700
700
700
Comments?
Hi Jerry. This is the best graphical comparison of XT vs XT32 that I've seen. Crystal clear.
This thread is transforming into an Audyssey experts thread, instead of just Audyssey Pro because these tests could have been done without Audyssey Pro. Maybe that's a good idea.
Mark
post #3596 of 4228
sadly, he's gonna have to agree to 90 day terms on that invoice, because the well is empty right now... frown.gif
i merely lead the horse to the water... it's up to the horse whether it drinks or not... smile.gif
@jerry... that is GREAT news, re: serial transfer rates... i'll give it a shot... hopefully tonight, assuming i get the pile of equipment that is outside the rack back IN the rack...
post #3597 of 4228
Mark
even a non-audyssey owner like me can see the difference. just looking at them, I would agree with your conclusion about hi end vs lo end, at least in your room.
I'm dipping my toe tips in the tire kicking waters...again redface.gif winter does that to me, look for "things to do" tongue.gif
this is the kind of objective comparisons needed to make "objective" decisions wink.gif
post #3598 of 4228
Comments?
Great work, Jerry!
post #3599 of 4228
If you are considering a unit with Audyssey, remember that the really big step forward is from XT to XT32. The Pro Kit is 'the icing on the cake' and allows for more measuring positions, pre/post correction graphs, the ability to edit the Target Curve to 'fine tune' the calibration, easy saving and reloading of different calibrations - for different room configurations (say for music and for movies) or to allow easy experimentation and the ability to go back to a 'known good' calibration, a more accurate, individually calibrated mic etc.
post #3600 of 4228
I got substantially different sub distances with the new version 3.6 . i have not tried to vary the sub distances yet to improve response around the xover.
System sounds very nice and for the first time phantom placement of speakers seems good in the DVE pan around the room test.
Anybody else tried the new version with two subs?
