Having compared the 3008 to the 4311, to put it simply, Onkyo performs better than Denon - in my opinion anyway.
) have never seriously considered one.
) The competition to Denon I considered was the Onk SC5508 and Integra 80.2. There seemed little to no rationale to justify the higher cost of the Int unit I strongly considered the 5508 which is IMO a good deal at the usual US street of $1.5K or so, basically the same cost as the 4311. Keith's situation with the strret cost in his country is different. Now I sought out and was given some of the same Onkyo over Denon "preference" SQ opinion as has been posted here, which I respect but tempered with several other considrations, in addition to those I mentioned above.
). So what if it's a little OT?
The measurement files can be saved. However, after the measurements are taken, there are several other decisions that affect the results, including choosing crossover values, choosing one of several target curves, choosing whether to engage the midrange compensation, and the curve editor. Any combination of these choices results in a unique set of filters that is downloaded to the AVR. If one were able to save and reload the filters, instead of having to re-run the entire process, conducting comparisons would be less time consuming.
Originally Posted by mjf_uk
I see, thanks for that. From what other people have said, it seemed like it was much easier and faster to change between saved calibrations. |
I meant cousins in the sense that they both carry Audyssey genes.
