Originally Posted by
spike9876
BTW, previously I was planning on getting XTZ, and since I'm now planning on getting the pro kit when it's available wanted to check if it still made sense in getting XTZ.
The Pro before graphs can be quite useful as a measuring tool but has limitations. here's how I see it:
The cons of Pro as your measuring system:
1. It has no real-time capability and is
much slower displaying results (measure min 3 mic pos, calc, upload data, download graph, etc). A sub placement exercise ("a measured sub haul"
) could be quite tedious.
2. It only measures FR and displays a simple graph. No waterfalls, decay, etc., etc.
The pros of Pro as your measuring system:
1. You are seeing the summed response from at least 3 spots in a way far more reflective of the data Pro will actually be processing.
2. No additional cost.
3. The measurements are already part of running Pro so no additional connections are required.
Spike, you seem like the kind of hobbyist (doing lots of measuring including placing room treatments, plugging ports, etc.) where spending a couple hundred on having a quicker and more comprehensive measuring system would be well worth it to you. And that probably applies to most folks on this thread.
