True. It's impractical (but if you had a Kinect ...) to compensate for movement without something like a Realiser. A deeper question is how much it matters to the end result. The EQ is a single static transform on the signal and will be more correct in some spots that in others.
On the topic of using systems for measurements, it has been repeatedly stated by Chris (audyssey) that to more accurately measure what Audyssey is doing, one needs to take multiple measurements at the same mic positions used for Audyssey. There was no mention of time alignment.
As I said I don't know if or how Audyssey compensates for phase changes.
I have posted that for OmniMic I used a small grid, less than 2'X2' and for Audyssey I use a slightly larger one, maybe 3'X3'.
The example provided by markus767 is ~ .7 m (2.3 ft).
