AVS › AVS Forum › Video Components › Home Theater Computers › Ceton Live TV Cutting out after new Video Card
post #1 of 9
I just changed out my AMD 6670 for a Nvidia 550 GTX. Now when I try to watch live TV it cuts out every 20-30 seconds. The audio stays but the picture goes, sometimes its long enough that my projector tells me no signal almost like the video output completely stopped from the card but the audio kept going.
-When I goto the Ceton Diagnostic I have no issues tuning channels.
-Happens on all channels, HD, SD, Movie and Basic
Any thoughts, fix, for this?
post #2 of 9
Does it happen when you play back recorded content or just live tv?
post #3 of 9
It happens on recorded content as well.
post #4 of 9
What's you refresh set at? 29/59hz is what most TV is at, 59hz usually best to set it at, but this being off should only give you flicker/dropped frame not a stall. What does it do if you play DVD/BD?
post #5 of 9
No issues with DVD/BD. 59hz
post #6 of 9
Anyone have any advice here? I'm dying...in my second week of LIVE TV not working, just keeps dropping out like it can't maintain the input!!
post #7 of 9
This happened after switching to Nvidia card...I'm thinking it has something to do with this card...
Color space settings? Anything?
post #8 of 9
If you still have the old card, swap it back in. If it still happens then the card change was coincidental to the problem. If it goes away and comes back when put the nVidia card back in then you probably have a bad card or driver issue.
post #9 of 9
OK, well I think it has something to do with Colorspace...
My Projector is set to AUTO for colorspace, when I set it to YCbCr(4:4:4) to match the video card it works fine. However launching BD's or files with MPC-HC does not work, it cuts out. If I switch it back to AUTO then TV doesnt work and BD's and files with MPC-HC do work.
Any thoughts?
