AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › My New Home Theater 2.0, Staggered Wall HT.
My New Home Theater 2.0, Staggered Wall HT. - Page 4
post #91 of 380
Originally Posted by kevin g. View Post
Landshark,
The poster frames are very cool, can you post a link? Pricing? I am looking over their site, now, and am not seeing those poster frames. I have a local theater that sells the posters they have overstocked, for like 5 bucks, and mine are aged already. If I don't get them up soon, the movies will be classics.
Here it is --> http://www.displays2go.com/Product.aspx?ID=7030
post #92 of 380
Today, I installed one of the two LED poster frame. Reason was I ordered 2 OutletLinc from SmartHome, but they sent only 1 OutletLinc device, the other one was a correct OutletLinc box, but with a SmartLinc switch inside! Apparently, SmartHome's QC/Packing Dept. isn't that Smart.... Will need to contact them for a replacement after the holiday.... mad.gif
Anyway, here's some update pics for 1 of the frame.
Smarthome OutletLinc at the left
The transformer tucked in nicely inside the recess.
Also I paired the OutletLinc to a motion sensor, so whenever I walk into the basement, the poster will light up by itself and I've set the timer to turn it off in 2 mins if no motion detected. I really like the effect as we will get to see the poster lighted up everytime we are there. No user input or flip a switch is needed. wink.gif I'll try to do a video when I have the other frame next week.
Edited by landshark1 - 9/2/12 at 5:28pm
post #93 of 380
Here's the video clip of the motion control of the LED light movie poster frame.
Down the road when we build the wet bar, the left wall of the entry, I'll also have the sensor to control the in cabinet and under cabinet lights too. smile.gif
post #94 of 380
That is pretty cool.
post #95 of 380
Awesome. And I like how you stand there for a few seconds admiring your creation wink.giftongue.gif
post #96 of 380
post #97 of 380
That's really cool and even better if the wife doesnt think its overkill biggrin.gif
post #98 of 380
That setup is pretty sweet. I really like the timer option. Good idea
post #99 of 380
post #100 of 380
Sick Gary!
Any possibility you can get them to fade vs. a hard on/off? I think it would add to the subtleness and elegance of what you are going for. Also, are those posters on the outside of your HT? I guess if they are outside then it doesn't really matter. Super cool regardless bro!
post #101 of 380
Sick Gary!
The Insteon OutletLinc that I'm using is a dimmerable controller. However, those LED poster frame just can't be dim due to it's very low load. And yes, they are mounted on either side of the door right before one enter the HT in the basement sitting/common area. Will build a wet bar there after the HT is done.
post #102 of 380
Hey Landshark, if you don't mind me asking was this the led display lightbox you bought?
http://www.displays2go.com/Product.aspx?ID=17645
post #103 of 380
That looks very similar, but this is the actual frame that I use. http://www.displays2go.com/Product.aspx?ID=7030 Still love them, durable metal frame, and doesn't feel cheap or easy to break after a few changes. smile.gif
post #104 of 380
Alright, finally I stole a couple days off from Big/Jeff's busy schedule to come work on my HT/fabric wall.
post #105 of 380
If anyone is counting that is 66 2x2 frames. There will probably be another 25+ of various sizes for the front wall around the screen, the borders around the random wall pattern, the doors and one odd wall that doesn't divide by 2ft evenly.
post #106 of 380
post #107 of 380
Originally Posted by NickTheGreat View Post
Yeah, I think Big is done for building and sanding frames for awhile. tongue.gif
post #108 of 380
A bit more progress today. We spent a whole morning just to sand all the frames at Big's shop. Then we head to my house to build a few panels.
The back of the panel stuffed with Linacoustic.
Testing our design concept, stagger/patchy random wall pattern.
We like it a lot! The design is "different" than most other fabric wall design. smile.gif
Edited by landshark1 - 10/22/12 at 6:20pm
post #109 of 380
Looks pretty good. Nice looking design.
post #110 of 380
Some pictures on my camera from todays playtime.
Window be gone:
three depths of panels arranged in random design, got 6 up today another 60+ to go.
A comparison to our original plan based on Gary's inspiration photos.
post #111 of 380
What is the 2nd fabric we are seeing? Did you need to wrap the front of your Linacoustic before placing it in the frame to prevent it from showing through the light colored fabric on the front of the panel?
post #112 of 380
Exactly. We tested with the Linacousitc underneath, we could quite easily see through the light color fabric. So we use Big's sample AT screen material to put it in between. Now we can't see it even when taking photos with the flash on. smile.gif
Edited by landshark1 - 10/22/12 at 9:32pm
post #113 of 380
post #114 of 380
http://spandexworld.com/c3/catalog/product/2195into
When showing your theater to family and friends, make no mention of buying anything at SpandexWorld, as the coolness factor instantly drops 10 points. Should someone ask about the inside of your panels, just mention they include a "synthetic copolymer" and quickly move on to your equipment rack.
post #115 of 380
Did someone say spandex? I've been taking group exercise classes for 20 years and I miss the good old days.
classic-aerobics-outfits.jpg?w=1050&h=689
post #116 of 380
Oh yea I like the way the panels are looking too.
post #117 of 380
Oh please let Hanes read this! Please, please, please! The possibilities are endless!
post #118 of 380
Originally Posted by jroyv View Post
See there is nothing wrong with spandex
If you say so......
post #119 of 380
My eyes!
Any stretchy clothing material should not be made to stretch past a size 4.
post #120 of 380
I'm really sorry I posted that link now.
