I didn't see a thread dedicated to the new MVC-to-AVI program, so I thought I would start one.
My first question is this. The program only outputs the audio into the left clip. I just made a test using footage from my JVC 3D Camera (before I returned it). I rendered out to uncompressed AVI.
When I marry the clips in Vegas, it takes the audio from the RIGHT clip, which is empty.
Is there a way to:
a) tell vegas to take audio from the left clip (I can't find anything that would do this)
b) tell MVC-to-AVI to save the audio in both clips (saving it only in the left clip seems kind of arbitrary to me).
I've been very happy with the Sony 3D Camera, but it doesn't support manual white balancing, and the JVC does. This is important to us getting a non-amatuer look. Now that the MVC-to-AVI program exists, the JVC camera becomes a viable option again. That is, if I can get the sound show up in Vegas.
To those who are doing this process, what are you doing to get the sound in?
thanks,
jack
Is there a way to:
thanks,
jack
