Two weeks ago, I got a very nice PN59D6900 from Future Shop (included 2 pair 3D glasses, 4 Shrek 3D movies and Samsung 3D BD-D5500 Blu-Ray player). I was happy with the deal and the plasma display is amazing (this was an upgrade from a 10-year old 50" Panasonic 720p commercial plasma with no TV tuner).
But there's a problem.... Periodically, while watching, I will notice the light level goes up and/or down at random times. It's as if the voltage went up/down and a light bulb dims. Sometimes it might go down and come back up in a few seconds or a few minutes later.
Note that I am not using any TV/Internet/wi-fi connections/sources. I am ONLY watching discs - some DVD and some Blu-Ray. I haven't even had a chance to try 3D yet. Immediately after I plugged in the TV, I did connect it to my router and updated the firmware. I haven't updated the Blu-Ray player yet.
When this occurs, I back up the player and re-play the scene and I never see the same change in level. It has also happened on several discs. So it's not the disc. I doubt that it's the player (hooked up with HDMI to RX and then HDMI to plasma). The RX isn't very good (Sony STR-DG720), so a new RX will be the next thing to buy.
Tonight I was watching a Blu-Ray disc and the brightness changed up/down over a period of 2-3 seconds, which is something I haven't seen before (usually it just goes up and then down again a few minutes later).
I have never encountered this in the past 10 years (same building) of watching the 720p plasma, but then again, it was a commercial display panel (no TV tuner), so it might be significantly more robust.
The set is only about 2 weeks old. I haven't changed any settings yet or done a burn-in prior to calibration. Is this light level change a known problem? I haven't talked to the Samsung or Future Shop guys yet.
The settings appear to be factory defaults:
picture mode: standard
cell light: 10
contrast: 95
brightness: 45
sharpness: 50
color: 50
tint: G50, R50
auto adjustment (disabled, can't select)
Advanced
black tone: off
dynamic contrast: high
gamma: 0
expert pattern: off
RGB only mode: off
color space: native
white balance: all RGB gain/offset are set at 25
10p white balance: off (disabled, can't select)
flesh tone: 0
edge enhancement: on
motion lighting: on
xvYCC: off
System/eco solution
energy saving: off
eco sensor: on
software: 001009 (updated on first day of ownership)
cell light: 10
contrast: 95
brightness: 45
sharpness: 50
color: 50
tint: G50, R50
Advanced
black tone: off
gamma: 0
expert pattern: off
RGB only mode: off
color space: native
flesh tone: 0
motion lighting: on
xvYCC: off
System/eco solution
energy saving: off
eco sensor: on
