AVS › AVS Forum › 3D Central › 3D Tech Talk › mitsubishi starter pack
post #1 of 5
I just got the 65838 with 3d starter kit that came with 2 glasses and bluray 3d disk. i hooked up the emitter as showed in directions but the emitter will only show two formats it says (L/R) side by side and (l/r) one on top of each other. when i put on glasses no 3d the 3d glasses are on. what step did i miss i wanted to show a 3d movie to kids.
post #2 of 5
Did you turn on 3D mode on the TV?
I have a 65737 and starter pack and set mine up with a Harmony remote to be to push one button to watch 3D. The other night for the Homerun Derby I thought all my glasses were dead. Turns out, for some reason the macro did not turn on 3D mode on the TV, even though the adapter was showing the merged, single fuzzy picture. Once I navigated to the menu and turned on 3D mode, everything was fine.
You have to hit the adapter remote until the two images merge into one fuzzy picture, then make sure that 3D mode is turned on on the TV. Unfortunately, Mits TVs do not seem to do a good job of auto detecting the proper 3D mode or even when there is a 3D signal in order to auto switch to the correct mode on the TV.
Good luck!
post #3 of 5
yes 3d mode is on. i have it set to checkerbox. when i hit the 3d mode button it only shows two settings and the picture never merges together to show 3d.
post #4 of 5
OK, stupid question....You say you a have 3D disk, but....what is the model of your BluRay player? Is it a 3D BluRay player?
post #5 of 5
its a sony blu ray player. i fixed the problem it was a mistake by me apparently i didnt follow all directions i had hooked up items in wrong order once i unhooked everything and followed directions the emitter read the 3d signal from the blu ray player
  Back to Forum: 3D Tech Talk
