room setup
post #1 of 7
I am thinking about rearranging my room and wanted to get some input to see if it would be worth it. I have tried to attach a scale drawing of my room for reference, but for some reason it will not load it so I will try and explain this the best I can. The room is in an "L" shape and the one section I am using for my HT is 10.5' X 20', and it opens up to the back game room that is 14' X 9.5'; I will try uploading the drawing later to give a better reference. Right now I have my TV centered on the 20 foot with my MLP centered on the TV. I like this setup because it allows me to have my 9.1 with wides and heights setup almost exactly to the Audyssey diagram.
What I am thinking about doing is centering my TV on the 10.5 foot wall with two rows of seating (obviously the back row will be up on a riser). The only reason I am thinking about doing this is becasue it seems it would isolate the system a little more and possibly give me better sound (although I would have to seriously consider room treatments as I would think this route may cause more reflections) and more than just one seat will be centered on the TV.
One other thing to keep in mind is that my AV rack is in the corner next to the closet at the bottom of the steps (all of my wires; cable, ethernet etc. come in through the closet) so I would need to use about a 25-30 ft HDMI cable and I have heard mixed reults using HDMI at this length especially when you are talking about playing Blu Ray's with Dolby and DTS HD master tracks. Going this route I amy have to lose my wide channels, but I think I can live with that. I figured in this setup I would set my speakers up for conventional 7.1 and also 7.1 with heights and switch depending on what I want to listen to at that given time.
Any insight from anyone here would be appreciated. TIA
room sketch 7-14-11.pdf 56.4658203125k . file
post #2 of 7
I am going to try to upload the diagram when I get home. I think my work computer is on the fritz and it will not allow me upload my PDF.
post #3 of 7
Well for whatever reason I cannot attach my drawing. It keeps saying "unable to load attachment." So I guess if anyone could let me know if setting up a HT would do better on a wider wall with shallow seating, or narrower wall with deeper seating I would appreciate it. Wish I could get this file to upload as I think this easier to visualize when you see it on paper.
post #4 of 7
I have uploaded a sketch of my layout for reference. If anyone would let me know how they would set it up and why I would apprecaite it. I am just trying to get the best sound possible.
post #5 of 7
Hi Smigro,
I did not see any losses on my 15m = 49 feet HDMI ( Supra ) cables yet ... I don't belief you should worry about that.
Some use of sound absorbing material would be advisable in your setup.
I just whished I had the space you have available :-)
bart
post #6 of 7
Originally Posted by exmo4all
Hi Smigro,
bart
Thanks for the response Bart. I have not done anything acoustically yet because of how much width my current setup has; I figured the best treatments currently would be behind me but with the fireplace there no where to put them. If you don't mind me asking, where did you get your HDMI cable from? I have a 30 ft Monoprice in wall HDMI cable that I pulled out because I started get red sparkles through it. I think the end that goes into the receiver may have got bent from me pulling my rack out once.
post #7 of 7
Bump for the weekend people.
