AVS › AVS Forum › Display Devices › Rear Projection Units › Service menu won't save my settings
post #1 of 2
Hello, I've got a 5 years old crt rptv, (samsung SP43T8).
The problem is that I want to lower the green cutoff parametter that is located in the "video adjustment" in the service menu, but every changes I do in this section are not keeped in memory after I come back to the normal mode.
It only occurs for the "video adjustment" settings with the component source. In scart mode or other modes, everything works and is memorised.
I hope it's not some weird bug. Have anyone already experienced such problem with their service menu ?
post #2 of 2
Aren't green settings reference? Couldn't you change R&B instead?
  Back to Forum: Rear Projection Units
