I know next to nothing about surround sound, but we're moving into a new home that is prewired for surround sound. It has 4 in-ceiling speakers and a 5th on the front wall above where the TV will be.
The room is about 18x18 and it's pretty open on one side and the back (open to the kitchen)
My TV - LG 55LW5600
(passive 3D)
My Blu-Ray - Panasonic DMP-BDT210
(3D Blu-ray DVD player)
My Subwoofer - BIC PL200
My Speakers - Not sure as they are in the wall and I haven't checked. But the guy before me spent quite a bit on his audio set up so I assume they are at least decent quality.
I'm not really looking to listen to anything at any loud volumes. I'm not worried about that deep pounding base or anything. I just want a clean sound at typical normal TV watching volumes. My listening will be something like 65% TV (...a little 3D), 25% Blu-rays (some 3D), 5% music, 5% video games.
Since my TV is a 3D set, I want to make sure the reciver will work well with it.
This receiver will also control a couple outdoor patio speakers so it will need to be able to control 2 zones.
Right now I'm looking at the Denon 1911 and the Pioneer VSX-102K
Are these decent choices for a $400 or so budget? or would you think about another unit?
What would you recomend?
THANKS!!!
My TV - LG 55LW5600
THANKS!!!
