Originally Posted by kwarny
Everything I posted were just artifacts? Could you please explain to me? So after the bass drum is hit, or in that one song where the ULF spikes twice and there is an increase in ULF, that is just the mic(s) of the recording company producing distortion? or some random from the outside environment?
That seems as likely as any other explanation, yes.
120Hz crossover, drivers with inductance low enough and suspensions linear enough to play cleanly >1kHz, actually.
No. The thing is, small rooms simply work differently than big rooms, but too many people think that the lessons of the latter are directly applicable to the former. (Well, in fairness they work the same, but the frequency spectrum of the modal region is quite different, so as a practical matter they are simply different animals.)
A succinct summary, from Geddes (who, after all, did write a doctoral dissertation on bass in small rooms):
"In a small room in the modal region, the SPL rises rather slowly at the individual modes as the energy builds up. The point about this NOT being like a propagating sound wave is quite correct. The pressure throughout the room basically rise and falls virtually in unison at every point. Think about the rise time of a mode compared with the wave propagation time. If you plot out the pressure around the room you will see that the wave travels around faster than the pressure can respond and the entire room pressure rises and falls with no apparent wave propagtion. Once we reach the modaly dense region then this effect goes away because the wavelengths are shorter and the modes are denser."
Unfortunately, I don't have a cite for that quote. I apologize for that.
Haven't been to one since I bought the ULS-15s.
