Originally Posted by penngray
Its all a choice. To correct some misconceptions, here are some simple points.
1. It takes a lot of displacement to get enough MEANINGFUL output below 15Hz. It does not have to be large boxes in room...I love someone posting someone else's DIY box trying to prove that is the only way to have bass, we could post 100 different designs for you, we can show sealed 18" cubed boxes with LMS5400s tucked nicely in the front corners of high end custom HTs but how about this subsystem....NO BOXES...27 liters of displacement, only 2000Watts needed for great bass down to 10Hz. This is better then 6 SVS PB13 subs and it extends lower then they do.....oh wait....it costs about the same as ONE PB13, less then JL Fathoms, less then Seatons submersives, less then the Captivator.....NO BRAINER there.
Find the subwoofer
2. No one cares what someone else likes or dislikes in terms of content, any post suggesting that everyone else should confirm to someone's choices of content is just silly.
3. Comercial subs roll off because of their design (driver designs, box designs, etc), no correlation to content requirements. Companies have to make a profit. The exponential $$$ increase for them in getting the lowest octave makes ZERO business sense.
4. Yes there is content below 20Hz, below 15Hz, below 10Hz....you can choose to want that content and you can choose not to want that content played back accurately in room. Choice is never actually something used as fact in a debate though
Conclusion.....I choose to make sure my system covers the most octaves. Once you have the best you simply never go back. All other systems are simply lacking, members of this very, very small club understand what Im talking about. The rest will never really get it.
Find the subwoofer
Did the wife give you permission to use your system again? Last I heard you have not used the system for a few years for family reasons!
Your reference is this.....
