I had no idea whose room it was or where, except that you thought it would be a useful example and I agree with that premise. (Though we think it's a useful example for different things. I think it's a useful example for what not to do.)
If that's your room, is it the one with the high-inductance I-B setup?
Since you've subsequently identified the room as yours, I really like the wall color. Have you thought about paining that cabinet to match? It sticks out in the picture at least.
So basically it was all about the deep bass, and who cares about midbass performance or how colored the mids are? Fair enough.
You're the only one talking about "ultimate." I'm setting the bar rather lower, at "competent." And that mains setup doesn't clear the bar.
Originally Posted by penngray
4. Its a family room, it hosts parties, it has kids over for pool parties. You honestly think its a room where speakers and subs can be on the floor at all?? Its not a bachelor pad, its not a student living space. It has to have style and speakers HAVE TO BE OUT OF THE WAY because the real world does not think they are remotely cool.
I agree generally that audio gear should be heard/felt and not seen. I don't want to see speakers, subwoofers, electronics, etc. in a room either.
That means it requires more thought (and often expensive custom work or time-consuming DIY) to put together a room incorporating high-fidelity audio.
It does not mean that incompetence should be excused or justified.
BS. I could point to any number of pictures that have been posted here over time, but I don't want to look for one when this one suffices quite well to prove my point:
Where's the "all" in that front stage? Unless you mean that the crappy subs' excessive inductance is masked by all the midrange and treble diffraction. But I bet you can really feel that bass!
Again, Penn, you really need to work on your interpretation of plain text. As is usually the case when you reply to me, I never wrote what you're ascribing to me. It's you and not me, because others don't have that same problem. 'm
1. Depends on the program material one enjoys.
2. True, with the caveat that the cheaper ways are usually pretty crappy up higher because they're crude long-coil, no-shorting-ring drivers with very high inductance. So one needs to also put multiple higher-quality (and expensive, if one wants them to keep up with the ULF) subwoofers in the room to cover 40Hz and up if one cares about fidelity.
"Offer solutions?" Get off your high horse. It doesn't take much thought, just volume displacement and power.
Nah. I've recently posted pictures of my current, temporary system's bass measurements, however. The subs are an XLS12+PR in the corner and two KEF HTB2's. (Yes, ultimate SPL is limited, but the bass is scaled appropriately to the small mains.) The setup methodology is Geddes'. For your convenience, I'll reproduce that measurement below:
For the record, the mains are all low-diffraction designs in free space, and the coincident tweeters are all at the same height, crossing in front of the listening position.
Its a picture from 6 years ago....
