AVS › AVS Forum › Audio › Receivers, Amps, and Processors › x08 and x09 Onkyo Failure Tracking Thread
post #1 of 60
In order to quantify the extent of the failures of the x08 and x09 mid and high level Onkyo receivers, I have created this thread to track failures.
Please only post if you are an owner of an Onkyo receiver effected by this issue.
Onkyo Press Release: http://onkyousa.com/press_releases.cfm?id=215
Integra Press Release: http://integrahometheater.com/press.cfm?id=216
post #2 of 60
Hi winston9332, what about the 3008/5008?
post #3 of 60
Apologies, I meant the X08 line to encompass the X008
post #4 of 60
No but my 876 HDMI board died in just two years. Just bought 809 hope it last lot longer than my 876. Nothing but issue after issue with Onkyo lately, how many years running now.
post #5 of 60
I have a HT-RC270 with issues so I selected X08 (2010)
post #6 of 60
busbeepbeep - did you have the noted issue or another one?
My 270 exhibited HDMI probs - no video out. Havent got it back yet, but could be what hdtv00 had
post #7 of 60
I've had the 270 for 4 days. Got it from Amazon Warehouse as open box. Hooked it up. Day 1 was fine. Came home on day 2 saw the receiver on and cycling thru audio modes. Unplugged for a while and it resets. Seen it turn itself on two more times. Trying to decide whether to try to get it repaired (if they'll even honor the open box) or just return it and go with something else.
post #8 of 60
They will likely repair it if you purchased it from an authorized dealer...
post #9 of 60
Hello,
The late Builds of the x08's did have the Serial Cable that caused all of the problems described above changed. I spoke with multiple people from Onkyo and others that have said the same.
That is not to say something else might go wrong, or that my very late build 3008 could have the problems that many have had. However, I am cautiously optimistic.
Cheers,
AD
post #10 of 60
Originally Posted by Audiodork View Post
Hello,
Cheers,
AD
What is the date that separates early from late models?
post #11 of 60
Hello,
Cheers,
AD
Interesting to know...any idea why only the 709/370 had the bad cable in 2011? Was it the cable or this gel in the end?
post #12 of 60
Hello,
I called Onkyo. I got an A-Stock 3008 as a Replacement for my B-Stock TX-NR3007. I was without my 3007 for almost 2 Months due to the Local Service Center turning into a fiasco.
First they released my 3007 telling me it was ready only to find out the HDMI would no longer process Audio from the HDMI Board, I initially took it there to the Video freezing while HDMI worked fine as far as Audio went.
After countless problems, finally Onkyo had my 3007 sent to Saddle Brook, NJ. At first, I was going to get a B-Stock 3008, but there were none available when my AVR was at Onkyo and they had mercy on me and Ordered an A-Stock TX-NR3008 for me.
When I called Onkyo in NJ (not the 800 Number) I gave them my S/N and was informed it was a super recent build and that the Serial Cable had been addressed on late production 3008's and other x08 Series.
I called other folks at Onkyo to ensure that what I was told was the truth,
I am going to extend the 2 Year Warranty to 4 Years by purchasing the Extended Warranty from ShopOnkyo as opposed to getting a 3rd Party Extended Warranty as 3rd Parties can often make it difficult to get Shops to Repair it and if say the HDMI Board is bad, they will just cut you a Check for whatever you Purchased it for less depreciation, If you have a 3008 or 5008 and got it from AC4L, there is a good chance the Check will not come close to covering buying a Replacement whereas Onkyo will either fix it or Exchange it.
Cheers,
AD
post #13 of 60
Hi Audiodork, curious what is your 8th and 9th digit of serial number?
post #14 of 60
Just sent my 3008 into Colorado for repair under warranty. I am experiencing all of the same symptoms mentioned above.
The 8th and 9th digit of my serial number is "0Z"
post #15 of 60
My HT-RC270 with issues has serial number "0Z" in the 8th and 9th digits.
post #16 of 60
Any folks with a 709 or 809 experience an issue?
post #17 of 60
Have a 370-video went out - had to reset, came back. Not sure why
post #18 of 60
Have a 370. All the back hdmi stopped working. The front input still works. Sent to an authorized repair guy- said they are having a lot of problems with onkyos and their service dept.
post #19 of 60
I want a 709 or RC370 so bad for all of the features... but I just have no faith in Onkyo right now with all of the problems I keep reading about at AVS.
post #20 of 60
Hello,
I would recommend reading the actual Owners Thread as opposed to the Failure Thread. As a corollary to the massive popularity of Onkyo is going to be naturally more reported issues.
All I can say is given the momentum they have gained since the x05 Series and the Black Eye over the Serial Cable issue the caused the x08 Failure Thread to begin with, I honestly think the x09's are going to prove to be well sorted out.
And while it looks pretty scary when seeing all of these Threads, at last updated, it was 21 AVR's that needed to be Repaired on the x08 Failure Thread. And considering the TX-NR608 was the most popular AVR on the Market, I think a certain amount of perspective needs to be had.
Cheers,
AD
post #21 of 60
Facts about the "failure thread"...
1. It is overly skewed.
2. There are EASILY 30 times the people posting in the various owners threads of the X08/X0.2, than there are in the two failure threads.
3. The "failure" if you do it yourself costs about $12 to fix. Most local shops(I'm in Chicago) will fix the problem the SAME DAY for around the same price as shipping it to an authorized Onkyo facility.
4. Not exactly "fool proof", but where ever you get a X08 or X0.2, you can call the 800# and find out if yours is in the "known failure" list.
post #22 of 60
No problems yet with my 708, keeping my fingers crossed.
post #23 of 60
Hello,
Cheers,
AD
Lets put some reality to the numbers..
According to the industry's market reports, in North America Onkyo sold 685,000 AVRs from January 1, 2008 to June 30, 2011..
Assuming a failure rate of 3%, that equates to a total of 20,500 bad AVRs, yet the thread doesn't even suggest a number anywhere close to that.. Something doesn't add up..
I wonder..
How many? of the reported failures were for installs that had inadequate ventilation..
Just my $0.02..
post #24 of 60
Inadequate ventilation is grounds for "warranty exclusion".
IT is easy to check an AVR for heat stress. There are parts in them that should "never get hot", they can easily cover them with some form of wax that melts at a certain temperature...and if the wax is melted...no warranty.
Technics and Kenwood used to pull that trick in the 80's and 90's.
post #25 of 60
Hello,
Cheers,
AD
I've been following the 709 owners thread so far... but it's still pretty early for the 2011 models. Although there is already one report of the HDMI inputs crapping out.
It just worries me when Onkyo included the 709/370 in the press release regarding the "continuous input change/non-responsive to commands" that affects the 2010 models.
post #26 of 60
Are referring to out of warranty repairs?
Or are consumers required to pay shipping for warranty repairs of a known problem?
post #27 of 60
So what if it is included? It is ALREADY DOCUMENTED all over this glorious thing we call the interwebs...
The PCB coating on some models was "over applied". I'm sure it WILL BE a problem on some X09 as well. Am I worried about it? No. Am I worried about it for my customers? No.
That is why these things come with a warranty.
IF there is too much PCB coating in ANYTHING...it causes problems. Remember the "laptop battery problems" from a few years ago? An "overabundance of PCB" was found to be the cause in a bunch of the battery fire/meltdowns.
post #28 of 60
I'm aware its documented all over the "interwebs" smartass... for the 2010 models...
If those particular 2011 models are included in the press release, then Onkyo is probably expecting the same issue (same parts maybe?) with some of them as well, right?
You may not be worried... but I find it really alarming that Onkyo may have let something escape QC again this year when it's turned out to be a legitimate issue with last years models, whether the frequency is overestimated or not.
post #29 of 60
I completely understand your point. However...
This PCB problem is noticeable, and correctable with-in 35 minutes of being "first out of the box".
IF you know what to look for, and you are confident to take 8 screws out of it...
Look at the 40-pin cable before you ever plug it in. If there is "excess goo"...return the receiver, or break out a can of cleaner and take 10 minutes cleaning it out. Is it unfortunate that you "might" have to do that? Yes it is.
But, if that is the ONLY PROBLEM your receiver ever has...I'd take that problem all day long.
post #30 of 60
I agree with you.... it could certainly be worse....
But it is sad I'd have to check for a problem on a brand new receiver. On one hand, at least it's "fixable"... on the other, it shouldn't be there to being with.
