AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › kdl 55ex710 question
post #1 of 6
When I'm watching the news I can't see the ticker tape bar on the screen. How do you adjust the vertical screen. I can adjust the wide part but not the virtical. Driving me crazy. Help an old guy out
post #2 of 6
There should be a wide button on the Sony TV remote that you can push to adjust the aspect ratio.
If you have a cable box or satellite box, make sure the settings in that box are setup so that it knows you have a widescreen TV.
post #3 of 6
With the remote, press Home. Go to the last item on the horizontal menu, it's called Picture & Display, then go to Setup, go to Screen, set Auto Display to OFF, change Display Area to FULL PIXEL.
That should do it.
post #4 of 6
That should do it.
Thank you much for the info I'll give it a try to see if it works ( no ticker tape type news at the moment) I have AT&T Uverse it might be them
post #5 of 6
We have ATT U-verse as well and it's NOT them. Factory defaults to a different setting that works fine as long as all you do is watch standard def. For HiDef, the above is the correct setting.
BTW, we watch CNN and ESPN a LOT! We couldn't put up with what you are...
post #6 of 6
That setting fixed it . Thanks a ton. Great picture on this tv
