AVS › AVS Forum › Audio › DIY Speakers and Subs › Replacement driver for Energy ES12-XL
post #1 of 8
I have an old Sub Energy ES12-XL. The surround on the driver is starting to peel off. I want to replace the driver. What's a good but responsibly price driver to replace?
post #2 of 8
post #3 of 8
It's easy to find a speaker to fit, buts a bit more difficult to find a speaker that will sound the same or better in the same box. Is there any chance you could find out the t/s parameters of the existing driver? If so then you could probably find something close at parts-express.com
post #4 of 8
Thanks for you reply, I was looking at Part Express, but didn't know which sub to get as replacement. I posted specs of the old driver in post #2. I'm not too picky on sound quality, just something to add a little oommphhs to movies and music. My sub is in a very small room, so don't need a bunch of power neither. I believe the old sub is 8 Ohms. Do I need to look for replacement of same Ohm?
post #5 of 8
"Do I need to look for replacement of same Ohm?"
that would be a good idea.
i'll see if i can suggest a driver.
post #6 of 8
this one looks okay in what i am guessing is about 3 cubic feet enclosure tuned to around 27 or 28 hz.
http://www.parts-express.com/pe/show...number=295-445
http://www.parts-express.com/pdf/295-445s.pdf
just check two things. first, make sure that the driver that it is replacing is a nominal 8 ohm driver, not a nominal 4 ohm.
second, make sure that it will fit. check the diameter and depth just to be sure.
good luck.
post #7 of 8
Ltd, thanks for the recommendation. That sub looks way more than what I intend to use, anything else you recommend in a lower price range?
post #8 of 8
Probably not.
Have you considered re-foaming? It's simple enough for a newbie to do after watching a couple youtube how-to videos. Call and find out if this kit fits your sub.
http://www.simplyspeakers.com/energy...t-fsk-12a.html
