Originally Posted by
XLR8TR
A subwoofer....? I got a "Stereo" system, but each channel has 3 speakers connected in parallel, each with 12'' built in woofers. So 6 speakers split in half for stereo. No need for an annoying subwoofer.
Sub woofers are only annoying if you have a crap one and/or it is not set up and integrated properly.
XLR8TR
Most stereo amps are designed for 2 speakers, which means two full range speakers capable of handling their own bass.
Rubbish. Amps are designed to deliver a certain power into a given load, and it is up to the user to decide if a given design is correct for thier needs and implementation. Just because an amp has 2channels does not mean you only have to use it in a 2ch system, not that that is what it is only capable of being used in.
XLR8TR
A 2.1 system I wouldn't even consider being stereo anymore, more like 2.1 surround-sound.
Stereo means three dimensional, not a pair of channels.
LF is also not directional and very hard to localise unless the sub is doing something wrong, eg distortion or a resonance. This is how come multi subbing a la Toole, Welti, Geddes etc works so well.
So using a sub(s) for LF support doesn't make it any less of a stereo system.
XLR8TR
If I wanted to use a separate subwoofer for my low-frequencies, I'd just build my own crossover from coils or capacitors, its not hard. Most stereo amps or receivers will let you make a cutoff setting for minimum/maximum for both the speakers and subwoofers.
This is an expensive way of doing it and difficult to match levels correctly and hard to get matching high and low pass slopes of decent order. Active gives more flexibility, control, does not waste power in passives and often has other features such as EQ and delay.
