Originally Posted by dwarner
I use my Tivo series 3 for Netflix, but it has a couple issues, and I'd like to know if the Roku would be a worthy replacement before buying one and setting up an account.
For multi-episode shows:
1. If you stop in mid-series, and come back later, does Roku make it clear what episode is the next unwatched one? If so, does it automatically jump to that one, or do you have to page through them all to find it?
(On Tivo, you have to remember the episode number/name, or write it down)
2. When done playing an episode, how many keystrokes does it take to play the next one (Two on the Tivo)
3. In lists of instant viewing shows does it show a graph indicating the amount viewed already? (Tivo: you need to check the details on each one to see what's been partially viewed)
4. Can you find and queue up new shows via the Roku interface, or do you have to go to the web, and log into Netflix to find new shows (Tivo)
1: when I come back it's either on the last episode I watched(If I didn't finish it) or on the next episode.
2. If I remember correctly, when I finish watching an episode, it goes back to the menu with the next episode there and the play box is highlighted. So it's just a matter of hitting the select button for the next epsiode to start playing.(But if there is 5.1 audio available, you have to manually select the 5.1 track for each title since it always defaults to the 2.0 PCM track.)
3. Yes. There is a bar that shows the amount viewed.
4. Yes you can find new shows form searching or browsing and add it directly to your queue.
