AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › Ye old Magnavox scanning for channels no remote
post #1 of 4
I'm trying to hook up a vcr via the RF connector and everything is fine except it won't go to channel 3 or 4 (or any other channel besides 2) I don't have the remote. How do I scan?
post #2 of 4
Menu? Sometimes menu will appear on those tv's when you press both Vol+ and Vol- together
Maybe Ch+ and CH- together.
There you go to auto channel scan while the vcr is open and it will add channel 3.
If it doesn't work, unplug it for a couple hours and channel 3 should come back in the choice of channels.
post #3 of 4
Just pick up a universal remote. Wallymart has them for under ten bucks. If your TV supports it go with either SVideo or Composite input for a cleaner pic.
post #4 of 4
That should work for most but not all video game systems which use an RF adapter. What're you using specifically?
Also yeah, you'll want to check to see if there's a menu button you can navigate with the volume and channel keys...
