Mac to PS3 streaming?
post #1 of 2
Hi all, I found a great media center program for my mac called Ps3 Media Server. I am able to connect via a crossover cable for stutterless 1080p streaming, however the program transcodes to h264 on the fly. is there any solution that will let me stream with a different higher quality codec than h264 or even the non-transcoded mkv file directly? I am convinced it can look better but maybe not.
post #2 of 2
As far as I know PS3 Media Server remuxes x264/mkv on the fly which means it repackages the video into another PS3 compatible container in real time so image quality should not be affected. Transcoding converts in real time into another format.
Serviio does the same trick, you might want to try that instead, you will have to apply the PS3 profile to the IP listed in it's main tab.
