Originally Posted by Nethawk
So your question is not buried, I will take a back seat stab at an answer.
I believe it would be common advice to invest a bit more in the Philharmonic 2 with RAAL. My gut feeling is that Philharmonic 1 exists for those who are striving for accurate speakers but have more budget restraints. I can't swear to it, but I believe this is what I have read.
One gent (frsimms?) on Audioholics had a friend who was going to buy Phil 1's and I believe he was going to provide his review but I have not seen it, nor do I believe I have seen one either here or on Audioholics, and I've been absorbing every word in both forums.
Here is one Audioholics post with a brief difference between the three, and of course Dennis' website has much more info.
Honestly, while my palate is more educated than my ears I doubt I would be able to detect a difference. I attribute the heaps of praise Nuance has provided on RAAL for my purchase decision, after reading most of his posts I didn't want anything less.
Good luck in your decision.
Hi I've sold exactly 2 Phil 1's, and the second pair isn't finished yet. The first was the prototype that I sold locally. frsimms' friend ended up getting the 2's. The RAAL obviously has more sales appeal, which is just as well since the Fountek ribbons are getting hard to find. If you A- B the 1's with the 2's, the sound stage is a little higher and deeper with the RAALS, and there's a little more air at the very top. If you A-B the 1's with a speaker with a good dome tweeter, the comparison is reversed--the 1's will sound more spacious.
