^Hi guys. Thanks for your expertise. This is interesting but I'll just restate that I did not mean to reopen broad, highly technical and theoretical debate on jitter. After all, I did not start a(nother) jitter thread in the Audio Theory section of AVS.
I have a practical question essentially about whether it's worth it to buy an expensive Denon player to get DL and I'd like to hear from folks who have tried real-world A/B listening tests wrt SQ improvement heard using Denon-Link ON vs OFF. So far the theory is becoming more abundant and test data remains underwhelming.
It occurs to me that the question with DL is actually akin to the passive biamping (assigning unused AVR internal amps to the same speaker, removing the jumper on the back of the speaker) issue in this sense:
1. we are talking about fairly subtle differences in SQ which is already at a high level
2. the Denon literature says it improves SQ
3. people offer various plausible-sounding theories as to why it should be true.
4. placebo effect, auditory memory and level-matching must be taken inrto account
By and large controlled listening tests reveal such biamping doesn't audibly matter, so one needn't bother. The same goes for biwiring; I hear it all the time from expensive speaker manufacturers and dealers. For example, my Dali Helicon 400s "should" be biwired.
However, unlike the aforementioned examples, AFAIK, the D-L ON/OFF test should be quick and easy to do properly, even blind.
I have 2 Velo DD10s and the AVRA100, for ex., vs your DD15s and the Denon flagship pre/pro. I'm guessing your room is probably better acoustically as well, since mine is a nightmare.
So Im understanding you to say that in your system CDs sound better DL than via SPDIF. Would you describe your gear and the SQ difference? Your findings seem consistent with
