Damn that picture always gives me the goosebumps
post #301 of 335
2/25/13 at 1:39pm
. I am assuming Dennis put in my order for the server. He said the wait time is 6-8 weeks. So about a month in a half to two months. Then he will load everything on their for me and set it up. Then he will program the tablet I am getting as well, So that will also take time. I am probably looking at just over 2 months before I have it in my system.
. Without you guys there is no way my room would sound as good as it does now. Anyway, back to the server. I am really looking forward to having everything at my command and I am really curious to see if getting the DVD racks out of the makes the room seem bigger. So just let me know if you got my info. One more thing. I listened to part of that demo disk.
. That about sums it up. It sounded amazing. I was just curious and I put my system in bypass mode(you know me). The total sound, from the highs down to the bass was just insane. I could not believe the bass my speakers were putting out on their own. It was truly mind blowing so thanks for that. It was a great day. Great people to hang out with while listening to a great system. I am sure Dennis will keep you posted and I will keep you updated on the server side of things.
Just check your wallet at the door. I don't want to be held accountable for any damage to it.
. Since I had to compromise on the picture size, I refuse to compromise on the sound. But Craig's setup everything setup right. In the right proportions. His sound and picture go hand in hand.
. Like 110" isn't big enough. The only other thing I would recommend you look into are room treatments. They will make a world of difference and you will hear what your gear really sounds like. In fact, I would do that regardless of any of my other comments. If you are not sure where to start with treatments, as I said many times, I would look into, and contact GIK treatments. They will really help you out. But enough about not being there. You are closer then you think.
