Hi,
I have an Infocus X1 that had the original bulb last for almost 8 years. After it died, I ordered a new lamp that worked for about 3 weeks before the projector started having problems again. Upon powering up, the fans come on, I hear a sequence of chirps (is this the lamp attempting to strike?), then the red LED flashes 3 times. I had the lamp replaced, but it does exactly the same with the new one. From what I've read, the ballast power supply could be to blame. It doesn't appear that this part can be ordered directly, so getting another projector for parts or finding a power supply on eBay seem like the only options. Is it worth taking to someone who specializes in electronics repair at this point? Is it worth trying to track down replacement parts? Or should I give up, sell the new bulb, and buy a new projector? Any suggestions would be appreciated! Thanks!
Chadd
Chadd
