AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Avr1912 or vsx1021-k
post #1 of 4
I have read thread after thread of both the Denon AVR1912 and the Pioneer VSX-1021-K. Everyone for the most part seem to like both of these. But the majority seem to lean to the Denon for the MultiEQ.
Before I finally decide on one of these 2 I was wondering if there was any more info I'm missing to sway me in either direction. It seems the Pioneer has a few more issue related posts than the Denon. Either way I don't think I can go wrong with either....Just trying to get any more input into the two I am trying to decided between.
post #2 of 4
I am considering the same two receiver and I was wondering what you ended up going for. Thanks!
Alex
post #3 of 4
I was considering the same 2 but the pioneer has a lot of bad reviews for hdmi failure rate.
You should look into the Yamaha 671, it's now down to the 1912 or 671 for me. which ever is cheaper.
post #4 of 4
Pioneer hdmi failure rate?
