AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › DIY 3.5mm cable
DIY 3.5mm cable
post #1 of 6
Hi guys I wondering if any of you know how to make this type of cable.
I've gotten that same cable 3 times from monoprice but it keeps failing on me in the exact same way!! one of the channels eventually starts cracking and then goes off...
So I was thinking of buying a thicker cable somewhere else or just making one myself..
post #2 of 6
Maybe it's the female connector?
post #3 of 6
You can make your own .. you'll need some decent quality 2 conductor shielded cable .. and the two connectors, but honestly I think you could do it cheaper by just buying a higher quality cable like this one . Those cheap cables always seem to fail at some point and we no longer use them in any install, its not worth the call back headache and expense, so buying a better cable from the start tends to cost us less.
post #4 of 6
Sweet!
Look mi sofa is around 14ft from the receiver, a straight shot nothing on the way and nothing pinching the cable..and I do not move as Im using it..I just use it to extend the cable of my headphones while I play video games at night that's all. Is that place reliable to buy from?
post #5 of 6
Originally Posted by Evildude View Post
Sweet!
I think so .. we use a lot of their product and quality has never been a issue
post #6 of 6
cables fail often in mobile applications because you are always twisting, bending, stressing it, but if a fixed cable fail u multiple times... something else is wrong.
  Back to Forum: Tweaks and Do-It-Yourself
