I wasn't sure where to post this so please forgive me if this isn't the appropriate forum.
I'm pretty ignorant when it comes to home theatre. I purchased a Panasonic TCp55GT30 this week along with a Denon AVR-1612. Is it best to run my components (hdmi cable, 3D blu-ray, and xbox) through the receiver or the television? It seems there may be pros and cons of each.
Also I've noticed what appears to be static in the video from my blu-ray player. I'm assuming my cables aren't up to spec. I have two cheap Dynex cables from Best Buy and one higher quality cable from monoprice. Can someone suggest the best hdmi cables for the price?
Also, I. A bit overwhelmed by all the settings from theses two devices. I would welcome suggestions from anyone with this setup.
Thank you.
Thank you.
I'm open to suggestions. I haven't really set a budget yet; I'm thinking maybe the $1000 range, which probably won't buy much.
