EDITED FOR DESCRIPTION:
Bacon Race Theater
Construction by BIGmouthinDC and Damelon
Design "shout out" to SMX/Sandman/Ruben using his theater as a template and working with BIG to make changes according to our taste and preferences.
Accoustical Plans by BPape
Room Dimensions and Treatments:
My "space" is 23'6" L x 16'4" W x 8'9" H. "room in a room" construction with a 1" gap between existing framed walls and concrete foundation walls. All side walls will connect to ceiling with RISC-DC04 clips. (The space inside of the "Inside" wall is 22'8" x 15'4" x 8'9" pre-drywall)
Ceiling is clipped & channeled from the existing ceiling joists.
All walls will be 2 layers of 5/8" drywall with green glue between.
28" wide, 1 3/4" thick solid coor door on the side wall. This is semi-hidden or hidden behind wall fabrics. Door Handle will be a black emtek, and hinges are wide-throw to allow for the 1" of treatments on the walls.
Soffit around the room inside of the drywall, which will be used for absorption and containing HVAC lines and conduit. On the inside/center facing side of the soffit is a "light box" which will contain some small recessed lights painted red. (Like a border to the middle-tray ceiling area) Soffit size will be about 16" wide x 10" tall.
Stage built using roofing felt with 2x10"s filled with sand and double 3/4" plywood.
Riser built using 2x12"s with insulation, and also double 3/4" plywood.
False screen wall 2'4" in from the front, which has a 130" wide scope screen, CineweaveHD from SMX. Throw is between 14' - 15' somewhere.
Projector is Sony VW95ES
Working with BPape on acoustical treatments, The room is black/red with Black seats, dark gray carpet, Fabric Walls (Black and Claret Accent FR701 GOM), black soffit, red light tray, black screenwall. Side walls will be 1" 3lb dense cotton, front wall 2" 3lb dense cotton, back wall 4" OC703.
7.2 speaker setup using Axiom Speakers (Epic 80 - 500 7.2, but with 3 identical towers across the front), a sunfire TGA-7400 7 channel amp, an Onkyo PR-SC5508 pre-amp, as well as a 16 TB media server.
Room has 6 columns, 4 on each side, and 2 on the rear wall. 4 of which house my surround speakers. We used square columns built into 3 parts. The center part being speaker grille, and the top and bottom parts having triple curved trim along the sections bordering the speaker grille. They are be 10" deep X 16" wide.
I started work as of 7/26/11.
Link to my complete cost breakdown of the theater, along with several links of where I acquired products
http://www.avsforum.com/avs-vb/showt...9#post21138019
PDF of this whole thread as of Second week Feb, 2012
http://www.mediafire.com/?zviy8yjbmn7lb8o
Latest Photos
Bacon Race Theater
Latest Photos
