AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Making the "Bacon Race" Theater
Making the "Bacon Race" Theater - Page 50
post #1471 of 1832
I think the other thing of note on the equipment room is that because of the pass through nature of the rack, the equipment room walls and door used the same soundproof construction materials as the theater.
post #1472 of 1832
Damelon - Did you use flat paint on your MDF for the soffits or did it have some sheen to it?
post #1473 of 1832
The black we used on the inside of the soffit and ceiling was a flat black. I wanted minimal light reflection.
The 'Antique Ruby' red had a Satin sheen
post #1474 of 1832
Thanks. That is what I was looking for.
post #1475 of 1832
OK, took all the assembled frames and put on the beveled edge with a table saw.
This picture will make a lot of table saw safety gurus cringe, It made my saw cringe.
One order of frames to go, hold the bevel on two.
So if you were making frames for 2" wall treatment, what would the best method be? Stack 3/4, 3/4 and 1/2 strips and do the same?
Posted to soon. "and into a two inch frame. These were 4 layers of 1/2 inch plywood."
post #1476 of 1832
Originally Posted by damelon View Post
As per your exact picture of the soffit, (the green line) the front part of the room's soffit is larger. The screen wall is 2'4" out from the front wall and the ladder area is lowered for the entire area.
Did you do anything in terms of channel and clip placement for the longer front soffit?
post #1477 of 1832
No the front soffit runs perpendicular to channels so you are already hitting every ceiling channel in the room no matter where you put it.
post #1478 of 1832
Update: Got a call from the Audio shop with my pre-amp. Just let me know they have it, the work was approved by Onkyo (which was a joke statement to me since they asked me for all of that information prior to shipping) and that it was on the bench. Lets hope I get it back before football season!
post #1479 of 1832
I finally finished reading the nearly 1500 posts. Awesome theater, and great job by you and Big to document the build. I feel that I have learned a lot, and I am sure others will for years to come.
I have had a question since post #56 about the height of the EQ rack. From the theater side, it seems low. I guess because of the riser height it visually lowers it in the room. From the back, is the top about 5.5 feet? (I am not sure how tall Big is). Did you ever consider making the top of the rack higher and using a step stool in the back to reach the top on those rare occasions?
post #1480 of 1832
The picture of me with the opening was me raising the opening because the guys who framed the room did it too low IMHO. Actually the only thing your routinely need to access is the disk player and if it is near the top no problem. If you want the rack higher put your rack higher. In the case of the Bacon Race the rack is on the lower part of the wall and visually doesn't intrude on Damelon's wall design as much if it were higher.
post #1481 of 1832
Very good point. I studied the pic you included, and it does kind of fade away into the shadows with the way the lights wash the walls and the rear columns. Yet another subtlety I missed the 1st time. Thanks.
post #1482 of 1832
Update: My amp arrived back at the house today. Going to cross my fingers and hook it up, hoping they resolved the problem....and.... yay! After a re-calibrating the unit (Reset to factory) watched a movie with no issues. Glad to be back!
Edited by damelon - 8/31/12 at 9:57am
post #1483 of 1832
The plug ins you have on front wall for your Subs, are they a dedicated line or tied in with rest of receptacles? I was under the inpression that you don't want them plugged into a power conditioner and they should be on there own 20amp circuit. I also have 2 svs pc13 ultras, so dunno if it's needed.
post #1484 of 1832
They are on a 20amp circuit, which is shared with the other receptacles inside of the room. (Not shared with the rack/equipment) They aren't plugged into a power conditioner, though they do have a surge protector. I didn't mind sharing with the room's outlets because I only really ever use those for vacuuming, which I don't do when the subs are on.
post #1485 of 1832
I've watched several movies now and it looks like the problem was fixed. Props to Onkyo (and Empire Audio) for correcting my problem free of charge.
Also: I picked up 4 dimmable UL-10 LED bulbs off of ebay to try to see how they might work in my CAN lights. Mostly to cut down on power and heat. What a weird test that was. The 4 bulbs only cost $16 total, so it was a worthwhile experiment. I replaced the 4 bulbs on the front part of my soffit with the LED bulbs. With the dimmer switch completely off, the first light actually came on when I put it in. I guess the dimmer does supply low current even when off. Odd. Then when I put in a second bulb, they both just kept blinking. Very strange behavior. So I think it is safe to say that you can't just directly put in LED bulbs in those utilitech 3" cans I have. Oh well, it was worth a try.
post #1486 of 1832
i was planning on using those same cans in my soffit do they really put off that much heat?
post #1487 of 1832
It wasn't a CON or anything, just think of it more as a general upgrade. With how cheap the bulbs were, I'd love to be able to get a cooler/lower power alternative if possible. I have the lights on in that room only really when I enter and exit at the beginning or end of a movie. If you left the lights on for an hour, they would be very hot to the touch, but you don't just go touching lights every day. wink.gif LED lights would also allow me to change the color temp and give a brighter light to the room.
post #1488 of 1832
I've got 15 of these lights in my room and, admittedly, I'd be nervous to leave them on 100% for several hours. They really do get hotter than the surface of the sun. However, I've been so paranoid about it that I've reached over the soffit face and felt all around the back/top of the can and the good news is that none of the heat seems to make it out of the housing. Don't ask me why the laws of thermodynamics have ceased to exist in my theater.
They come with 50 watt bulbs and I was considering replacing them with the 35 watt variety which you can pick up on Amazon in a bundle for like $15, rather than $10/piece at Lowes.
As it stands now, all of my lighting is Insteon so I just have the on-level programmed for 70% which keeps everything nice and cool (ish) but if someone accidentally double-taps the on button then they go to full - sunburn inducing - brightness so I'll probably go the 35 watt route and take it from there.
*** Note: I should also mention that the cans supposedly have a heat temp sensor in them that will make the light start flashing if it gets too hot and I've never witnessed this occurring so all the worry is probably much ado about nothing.
post #1489 of 1832
I just put 6 LEDs in my kitchen cans and installed a dimmer specifically rated for LEDs. Unfortunately I can't find a picture of the exact lights, but it's the bulb, transformer(?) and trim ring in one. The really nice thing about the install is that they can be installed in a standard 4" ceiling box as well. Wish I knew that in the first place and I wouldn't have installed cans. Anyway, I noticed that they only dim about halfway and then start flashing. It's very annoying. Sometimes, if I set the dimmer where I want it and THEN turn on the lights, they stay dimmed WITHOUT flashing, but not every time. It's SOOoooo confusing. LOGANESS wants them on full when she's cooking anyway, so I guess it really doesn't matter. And I like to eat, so I don't argue.
My point is that , yes, there have been issues with dimmers not actually turning off, other than incandescent bulbs, all the way.
post #1490 of 1832
So that is probably the deal. When "OFF" the dimmer supplies a small current, which is enough to make 1 LED bulb light, or 2+ to flash. When all 4 were in, I think I could probably up the dimmer to get them to all come on. But I wouldn't be able to turn them off. In the grove thread, aaustin mentioned he had to use a resistor to take off that minimal output. If I had to replace my dimmers, I"m not interested in the bulb switch. We did replace a lot of our down lighting in our kitchen to LEDs and had 0 problems just replacing the old with the new. Then again they aren't mini LED bulbs on a dimmer.
post #1491 of 1832
LIGHT TRAY DETAILS
The light tray design from a previous post.
The bottom piece is 5 1/5 inches wide 3/4 MDF, the upright is 6 inches tall 3/4. with two additional decorative 1/2 inch strips of 4 and 2 inches. All visible edges to be rounded.
BIG - Is this the sanding sealer you used for the MDF light trays? What is the process for this to get a good painting surface? I've never worked with this stuff before.
post #1492 of 1832
Yes, that is the stuff. So the way it worked is that you build your MDF object. (Column, Soffit, whatever). Then you want to do any rough sanding to get any sharp edges off, etc. The sanding sealer is used primarily if you aren't staining, but going to paint over it. You just paint it on roughly, sort of like a lacquer. Then once it dries you can use a fine sand paper to smooth it down for a good smooth painting base and sealing the pores. If you have ever tried to paint on MDF before, it's interesting. Especially with Latex paint, since it doesn't like to stick to the MDF the way you want.
post #1493 of 1832
Thanks for the info Damelon. So rough sand, sealer, fine sand, paint. Got it.
post #1494 of 1832
I'll add that I had good luck painting the MDF that I added to my door by applying 1-2 coats of an oil based primer before painting. The oil based seals it so that it doesn't swell from the water based latex. This way you get your sealing and priming out of the way in one step. Kill two birds with one stone I guess.....
post #1495 of 1832
I think that Minwax product has been discontinued for air quality reasons, Last time I looked for it they had marked the gallons size for clearance and I bought the last three they had for $9 gallon. Haven't seen it on the shelf since. Just recently I had good luck priming MDF with a PVA drywall sealer. The active ingredient in the drywall sealer is formulated to limit the absorption rate of drywall paper and mud. It seams to have the same effect on MDF as it did not turn the surface rough like a latex paint.
post #1496 of 1832
Thanks for the info Big.
post #1497 of 1832
isn't the cleanup from oil based a pain? and what about the fumes ?
post #1498 of 1832
lowes is till listing it on there site and at the local store near me but that doesn't mean it going to continue to stock it
post #1499 of 1832
Yeah, the cleanup can be a pain since it doesn't wash off with water. You have to use paint thinner or mineral spirits. I just buy the cheap roller tray inserts and less expensive rollers, do my two coats, and then throw them out. I didn't think that the smell was that bad. I'm sure that it wasn't any worse than the sanding sealer.
I went with the oil based primer mostly because it was a lot cheaper than getting the sanding sealer and a latex primer.
I like BIG's idea of the PVA drywall sealer though as well.
post #1500 of 1832
The biggest problem with MDF is the edges, If you will have exposed edges I still like the Sanding sealer, Apply, sand, Apply sand, Prime, sand, Paint, Paint. Sometimes some wood filler needs to be added to the process depending on how well the boards were cut and assembled. On the Speaker builder forum a lot of the guys use Bondo on the edges and seams then sand and finish.
