AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The "Bacon Race" Theater / Patio / Bar Project
post #1 of 2306
EDITED FOR DESCRIPTION:
Bacon Race Theater
Construction by BIGmouthinDC and Damelon
Design "shout out" to SMX/Sandman/Ruben using his theater as a template and working with BIG to make changes according to our taste and preferences.
Accoustical Plans by BPape
Room Dimensions and Treatments:
My "space" is 23'6" L x 16'4" W x 8'9" H. "room in a room" construction with a 1" gap between existing framed walls and concrete foundation walls. All side walls will connect to ceiling with RISC-DC04 clips. (The space inside of the "Inside" wall is 22'8" x 15'4" x 8'9" pre-drywall)
Ceiling is clipped & channeled from the existing ceiling joists.
All walls will be 2 layers of 5/8" drywall with green glue between.
28" wide, 1 3/4" thick solid coor door on the side wall. This is semi-hidden or hidden behind wall fabrics. Door Handle will be a black emtek, and hinges are wide-throw to allow for the 1" of treatments on the walls.
Soffit around the room inside of the drywall, which will be used for absorption and containing HVAC lines and conduit. On the inside/center facing side of the soffit is a "light box" which will contain some small recessed lights painted red. (Like a border to the middle-tray ceiling area) Soffit size will be about 16" wide x 10" tall.
Stage built using roofing felt with 2x10"s filled with sand and double 3/4" plywood.
Riser built using 2x12"s with insulation, and also double 3/4" plywood.
False screen wall 2'4" in from the front, which has a 130" wide scope screen, CineweaveHD from SMX. Throw is between 14' - 15' somewhere.
Projector is Sony VW95ES
Working with BPape on acoustical treatments, The room is black/red with Black seats, dark gray carpet, Fabric Walls (Black and Claret Accent FR701 GOM), black soffit, red light tray, black screenwall. Side walls will be 1" 3lb dense cotton, front wall 2" 3lb dense cotton, back wall 4" OC703.
7.2 speaker setup using Axiom Speakers (Epic 80 - 500 7.2, but with 3 identical towers across the front), a sunfire TGA-7400 7 channel amp, an Onkyo PR-SC5508 pre-amp, as well as a 26 TB media server.
Room has 6 columns, 4 on each side, and 2 on the rear wall. 4 of which house my surround speakers. We used square columns built into 3 parts. The center part being speaker grille, and the top and bottom parts having triple curved trim along the sections bordering the speaker grille. They are be 10" deep X 16" wide.
I started work as of 7/26/11.
Link to my complete cost breakdown of the theater, along with several links of where I acquired products
http://www.avsforum.com/avs-vb/showt...9#post21138019
PDF of this whole thread as of Second week Feb, 2012
http://www.mediafire.com/?zviy8yjbmn7lb8o
Latest Photos
Some initial 3D Renders of the Pool/Patio Project (Outdoor theater is not in the render)
Current Progress of Patio - End Phase #1 (Under-Deck, Bar/Grill, and Hot Tub Area)
Edited by damelon - 10/20/13 at 6:04pm
post #2 of 2306
I have great expectations for this Theater. The space is perfect. No windows, good ceiling height, no significant obstacles and an experienced home owner/theater builder.
post #3 of 2306
This one sounds like one to watch! An experienced builder with great local mentors and a great space to work with. Very jealous of the space! Good luck!
post #4 of 2306
Isn't the stage a little on the tall side?
post #5 of 2306
Subscribed. Sound proofing plan sounds very similar to what I would like to do when my project begins this fall. Hope there are going to be lots of pictures...
post #6 of 2306
Yes, I was basing it off of another stage construction which I liked, but the height isn't set in stone. I may use 2x6's instead of 2x10s. The design would be the same, having a curved front lip and a second curve halfway down. I'm actually in the process of discussing reflection points now with Bpape so a lot of room dimensional adjustments will be hammered out soon.
post #7 of 2306
I think Damelon likes Sandman's and this stage design. It is also my favorite. Screen wall may vary.
Sandman's
I actually like the proportions of Sunset Cinema step a little better, the wings come out farther on the sides. With the two levels you really need to make the main section tall.
post #8 of 2306
Sandman's
I actually like the proportions of Cinema Murry's step a little better the wings come out farther on the sides.
100% correct, thanks BIG. I was too lazy to search for a link! I too like Sunset's proportions better, and the incredible background art helps too
post #9 of 2306
About the same size I have, I'll be following to see how it comes along.
post #10 of 2306
~ same size room as I have, ~ same design ideas...subscribed.
Only thing I'm doing different and you might reconsider is screen aspect ratio. Unless I read you wrong, a 130" 16:9 screen
I'm not going to have a lens either but I am going 2:4:1, will be doing the zoom method, there is a thread about that on the constant image height forum, it's worth a read. I have never heard of anybody who went with widescreen aspect ratio and was unhappy about that.
post #11 of 2306
Count me in! I'll come along for the ride, too!
post #12 of 2306
Somehow I was envisioning a single level stage.... The second step stage design reduces the visual heft that I envisioned.
I was also thinking that an 8' 9" height, with a 12" stage, plus the soffits, is creating several nearby boundaries to the speakers. And aren't the 1/4 wave lengths off these boundaries are going to cause nulls?
And that maybe less is more? Less sand, less work slugging the sand.
post #13 of 2306
You read it right. And trust me, I've read the CIH thread a few times now. One reason I said to feel free to argue with me on that topic was because maybe I just need convincing. I did watch a fair bit of HDTV format things on my old screen, but probably more movies than shows. So I'm up in the air about it.
Well it was a 10" stage plan not 12", and chances are the soffit will be about 10" or so around the edges of the room. Bpape didn't think the height was a big issue and plans to use the soffit as a treatment as well. I will likely lower it to 2x6s or 2x8s when the time comes. And you're absolutely right about the sand! a lot less work! I think SMX said he used 4,000lbs of it to fill his at a 2x10" height. Crazy!
Just finished a lot of discussions with Bryan (bpape) about 30 min ago and we're going to move the entry door to the left rear corner to make adding side treatments easier with the door opening inward followed by steps up to the back of the riser. We'll use ductboard for HVAC inside of the soffit, surrounded by MDF casing with supply in the front and return in the rear. Caulking around every seam, etc. The equipment room will also be de-coupled due to the rack opening to the rest of the theater.
post #14 of 2306
For me, the aspect ratio decision was driven by what I plan to use the theater for (lots of movies - majority of them cinemascope; a fair amount of gaming - 16:9; not a whole lot of TV or sports). I had enough height and width really to go either way. I wanted cinemascope "epic" movies to have maximum impact, so started down the 2.35:1 path - but after shooting movies for a couple weeks on a temporary muslin screen to test out various screen sizes, I came to the conclusion that there are a fair number of 16:9 or variable aspect movies that I also wanted to have a high impact / level of immersion. So I opted for a custom aspect ratio that gave me the width I wanted for 2.35:1, and the height I wanted for 16:9 - a 2.125:1 ratio (136" x 64"), CIA more or less. CIH didn't seem to be what would work best for me.
I'm also zooming - no plans for a lens any time soon.
post #15 of 2306
Here are my "BEFORE" pictures of the space.
The only pesky thing in the way is this drain pipe located at the front top left corner of the space, but since it's right where my inner wall will be, I will just frame around it. This will be hidden inside of the soffit, so no one will ever see the bump in.
post #16 of 2306
First thing to go is that stupid bump out with two doors
And then part of the area behind where the movie room, where I will recess a bar/kitchenette into the wall of my rec room. The entry way to the bar will also serve to enter my equipment room and my movie theater.
post #17 of 2306
Yeah I've noticed this a lot too. A lot of material uses the in-between aspect ratio. I'm so used to the bars over time that I just let them do their job, but a lot of the movies where you want it as big as possible are usually scope. What to do!?
post #18 of 2306
Hold it...you're in NoVA and managed to escape being "outed" for a long time? How is that possible? Folks in NoVA usually want to jump on the bandwagon. Something's awry here!
In all seriousness, welcome. Glad to see you posting a thread. It's also nice to see another NoVA build popping up. They have become scarce of late.
Regarding the 2.39:1 CIH question...go for it! I too was on the fence but I jumped in and would not go back. There is something about seeing a widescreen movie as intended by the director. My screen is an SMX 2.39:1 with a 130" diagonal measurment. I LOVE it!
Good luck, and post a floor plan when you are able.
Oh, and consider resizing your pictures to 800 x 600 or posting to PHotobucket or the like. It will make it much easier for the forum members to see (we're a lazy bunch and we don't like to click timy pictures to see larger images).
post #19 of 2306
Is that Michael Jackson? Or Ozzie? What the heck is going on in NoVA?
post #20 of 2306
be nice if pictures were larger for the build if possible
post #21 of 2306
Note to OP - you can go back and edit your prior posts and imbed the pictures that are attached to the same post.
Click the thumbnail to show full size.
Right click the thumbnail and click "copy image url" or something similar (put the url of the big image on the clipboard)
Go back to the original post and edit it.
Select the insert image icon, and paste the url you stuck on the clipboard earlier.
That's how I inserted the image of MJ above.
post #22 of 2306
On the name for this thread, How about Making the Bacon Run Theater.
post #23 of 2306
Hehe my wife goes a bit overboard on Oct 31. It's our skeletal butler. We can call him Ozzie if it makes you happy.
By the way I removed the attachments so your link doesnt work now so I just inserted the new one in this quote.
Done!
I've mostly been a thread lurker... what can I say. I only had a half dozen or so posts until recently. What can I say, if I posted earlier I had the risk of mentioning a future build plan and then I might run the risk of getting loganed.
post #24 of 2306
So I have the original pics, which are all high-res, but shrank them to 1024x768 so I could upload them. Some people are saying resize to 800x600 and others say larger... is 1024x768 adequate?
I also changed them to links on photobucket. Let me know if that is better.
I will upload all of the high-res pics to an online picasa album as well and link the enitre album as well (Like 4k x 3k res), so that anyone interested can get close-ups if they want.
post #25 of 2306
So let's cover this topic for a minute, as this is the time I need to really hammer down this decision. (Before I do my wiring and screenwall!)
If I get a scope screen, it would be SMX CineweaveHD or a SeymourAV CeterStageXD. I was initially looking to buy a JVC X3 as my projector. (I may do 3d eventually, but not active. And if I do it, it will be using the dolby method so I won't need a silver screen. This is future though, so don't worry about it. Basically, I don't need a 3d projector. So keep that in mind) Looking at the ProjectorCentral calculator, in order to fall in the green area with the 130" diag (And I'd even prefer the 130" WIDE one), I'd have to be at maximum 2x zoom at a 13'7" throw. Not sure if I should be considering another projector based on this. Though I consider myself generally well versed on a lot of things, I have to admit when it comes to how Zoom affects the image or how this will play into the "zoom" part of CIH, I really don't know much. So time to hammer me with suggestions.
post #26 of 2306
I would say stick with 1024x768. Resolution for pics on a forum can be a tricky thing to please everyone, since not everyone runs their monitors at the same resolution. Anything bigger than 1024x768 usually requires to scroll left and right to see everything, whereas anything lower (IMHO) looks just a little too small to get some good detail.
Looks like this'll be a great build, subscribed!
post #27 of 2306
I just upload my pics as I take them without resizing direct to Photobucket the rest is automatic. I can tell you though with the popularity of the AVS forum if you keep this thread well stocked with progress photos you will exceed the "free" bandwidth limitation of Photobucket and need to pony up the annual "Pro" fee. It's not much.
post #28 of 2306
That is still a very real risk! He's the type that rubs off on you occasionally. Some of us have been able to resist his "charms" and continue moving forward past the finish line...others...not so much!
post #29 of 2306
Much better, IMHO. When I started my build, I resized all of the photos to 800 x 600 before uploading to Photobucket. It mad ehte photos much smaller and I've not had an issue with exceeding bandwidth for Photobucket. Sometime during my build, they started automatically resixzing photos, so it's not necessary to resize. Also, monitors grew in size, so now 1024x768 is a great size to use. BUT, as Biggy said, watch the bandwidth usage.
Looks like a good build...SUBSCRIBED!
post #30 of 2306
Looks like a great build to follow. I would go with as big a screen as you can fit on the wall and make it CIH, but keep it under 80% of the width of that wall. Smarter folks than me have recommended that limitation.
Are you planning DD and GG, or put a layer of plywood on the studs before the first layer of drywall? (see http://www.avsforum.com/avs-vb/showthread.php?t=1127266 from KNKKNK)
