AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The "Bacon Race" Theater / Patio / Bar Project
The "Bacon Race" Theater / Patio / Bar Project - Page 43
post #1261 of 2308
comparison of a bunch of the ones dicussed.
The cross hatching is about an inch square in the following from Home Depot
what I have, Masland Quadrate
Also available
What Sandman has (he got a guy to crawl on his hands and knees and dye the stripes red)
Which carpet did you actually go with, any of these? I am trying to compare but can't really tell.
post #1262 of 2308
Made a trip out to lowes and found a carpet I liked. It's also a square pattern but larger and has a distinct "relief" to it. It's supposed to be all black, but because of the cut it appears black and dark gray. The price is very good.
The style is this
And the color example online, though it is much more pronounced in this image than it really is.
The color difference is much more blended than the photo.
That's what I got. I purchased it from Lowes.
post #1263 of 2308
So it is, hmm, wish they had it listed on their website.
post #1264 of 2308
They used to have it online! (Thats where those top two photos came from) But now that I'm looking, I don't see it. There were some at Home Depot and some at Lowes which were all close competitors for my final choice. I went to several "Carpet" stores and found absolutely nothing that I liked compared to the ones at Lowes/HD. When I saw this last one though, i knew it was exactly what I wanted. It is a pretty thick carpet though, so it messed with the door threshold we had. The door with the seal was too low for the carpet, and in order to make the door clear the carpet we had to trim the bottom. That ended up leaving a gap between the threshold and seal. It does mess with the soundproofing since there is an air gap until I raise the threshold, but in all honesty I have yet to watch a movie in there when anyone else is in the house and NOT in the theater, so it's not a high priority.
post #1265 of 2308
Did Lowes install the carpet for you damelon?
post #1266 of 2308
No, my wife is a real-estate agent, so she has her go-to guys for HVAC, carpet, paint, etc in the area. So our carpet guy had his installers come in and install it (They did the padding too) They did it very quickly, and it was a decent job.
post #1267 of 2308
D, Bzbase thinks that your carpet would look good in his dark purple room, stopped in his nearby Lowe's today. Does style Silver Lake, and color LO16 Gothic suite ring a bell? The sample looks so Black.
post #1268 of 2308
D, Bzbase thinks that your carpet would look in his dark purple room, stopped in Lowes today. Does style Silver Lake, and color LO16 Gothic suite ring a bell? The sample looks so Black.
They both do sound very familiar. I looked at it, that's for sure, and I'm almost positive I got silver lake as the style. The problem with samples on that carpet is that the small pieces are way too small to show how it looks.
post #1269 of 2308
damelon,
what version of unRaid are you using? I'm planning to take the plunge and migrate my WHS to unRaid in the next few weeks, and I'm not sure if I should go with the latest stable release (4.7 I think), or try out the beta version.
post #1270 of 2308
damelon,
I am running 4.7. Have not yet felt the need to go to v5. I feel safer here.
post #1271 of 2308
Runnin 4.6 here with no issues.
Tim
post #1272 of 2308
I'm running 5 beta 13. Have been for almost half of a year now with no issues. I had to go with beta 5 to support my 3TB hard drives, as they are not supported in version 4.
I use the ps3mediaserver plugin, the APC ups plugin, the myMain menu thing, and I think that's all.
Been running great so far.
post #1273 of 2308
The unRaid forum is very helpful, but I feel like you have to understand everything to, well, understand it.
Aside from 3TB drive support, are there any other advantages to version 5? I'd really like to set this thing up and not have to worry with it for a while as the rest of this year is going to be very busy!
post #1274 of 2308
Well with the new version came many bug fixes as well, but also it is still labeled a "beta", so there are new problems introduced. Version 5 has been in beta for a VERY long time though. I went with version 13 because it seemed to be the most stable version at the time. I haven't had a single problem in the last 6 months. (Or the entire time, depending on how you want to look at it)
It really depends on what you want it to do, etc. I needed to run version 5. If you aren't using 3tb hdds, there is no real need to run version 5. But then again, it's been out for so long now, which means all of their fixes and improvements have been focused on that version for a very long time, as well as plugin development. I'm surprised it isn't out of beta yet.
I love that program though. The entire server has such a small footprint on that thumb drive. Backup is so simple for the server configuration. The auto-spin up/down works great. Yeah writes are a little slow to the array but almost every time it is a write once, read many type of deal. I'm able to play all of my full quality blu-ray mkv's without any problems over the network.
post #1275 of 2308
version 5 has a new GUI...
I have considered testing v5 in a non production environment, just haven't...Might be worth a look one day.
V4 has been solid to date, so I just havent seen the need to upgrade as I do not have 3TB drives yet.
post #1276 of 2308
Closeup of Light Switches and Doorknob
Any reason why you didn't go with a grafik eye setup besides maybe cost?
post #1277 of 2308
Well cost definitely. That and need. I just didn't need it. I can RF remote the lights if I need to, but I rarely ever even need that. I just turn on the lights when we go in the room, and turn them off when the movie is ready to start and sit down. I guess I never understood the point of advanced lighting macros for a movie room. Wasn't something I ever really cared that much about.
post #1278 of 2308
What lighting system did use?
post #1279 of 2308
Materials 4 Leviton RF Dimmers Smarthome 266.52 http://www.smarthome.com/45071Z.html
Materials 4 Black Face Kit for Leviton Dimmers Smarthome 7.48 http://www.smarthome.com/86558BK.html
From Damelon's cost breakdown post: http://www.avsforum.com/avs-vb/showt...9#post21138019
post #1280 of 2308
What do you have wired to the switches? I see 4 switches, that mean there are 4 zones? Whats on each zone?
post #1281 of 2308
Thanks for pointing out the cost breakdown cdika! I was ready to post a link when I saw your post. I tried to make that in the first place so people could look it up but I guess it does get lost in the middle of the thread.
1) Side and Rear soffit lights
2) Stage soffit Lights
3) Ceiling Rope-Lights
4) Riser step-lights
And to be honest, I am not thrilled with those step lights. I may switch them out. They don't put out enough light to really even see that they're there. Needs to be a little brighter.
post #1282 of 2308
Any reason someone couldn't use a set of Lutron Maestro IRs? Are the Leviton's better? I was going to go with Maestro IRs for wall sconces, can lights, and then some regular switches for the rope lights (color changing LED, so they will be turned on and off via remote anyway) and for the star ceiling panel that is just on/off. I haven't purchased yet, so I am just asking...
http://www.dimmers.net/maestro_ir.asp
post #1283 of 2308
There is no reason you couldn't use those. However I wanted to use RF/Z-Wave and be able to control them without directly pointing at them. Based on where they are in the room it wouldn't be a big deal for me either way, but I prefer to not require Line of Sight, and my harmony supports RF so it worked great for me.
post #1284 of 2308
Makes since. Thanks for the clarification. My light switches will be to the side and slightly in front of the seating area. I just figured that they would generally be controlled once, maybe three times (in case of a bathroom/food/phone stop) during a movie. Plus my Harmony One isn't RF.
Thanks again. Now back to just watching your build continue.
post #1285 of 2308
So looks like the plan is that on the wall exterior to the movie room we are going to put a stone veneer and sconces. So the entryway will need to be finished up (Painted). This will also mesh into the bar area behind the theater, but I'm not sure on the timetable as we are looking to do a lot of outdoor work like patio, pool, hot tub, etc. My wife will be the driving force on priority there as I'm sure we can't do it all at once. Still, I will provide photos and updates once any of that happens, even though it isn't technically part of the theater.
post #1286 of 2308
I am reaching the same conclusion after having installed a couple more of these bargain lights (Under $10)
I did some searching based on something to stuff in a standard single gang box and run on line voltage. Found a couple LED lights.
http://www.lightinguniverse.com/led-...e_g547088.html
http://www.laststoplighting.com/p6827-30.html
on LED lights 3000k isn't too unnatural of a color light, if you go higher they start getting Bluish/white.
The first (cheaper) doesn't mention if they are dimmable would need to check.
post #1287 of 2308
I dont know if it's the bulb itself or the actual cover. I dont think that cover lets out a lot of light in general. As long as it has a cover like that, I dont think the dimming part would matter. However I think something like this would be necessary to give out enough light to actually make it more visible.
http://www.lightingdirect.com/elco-e...ce=gba_1661374
post #1288 of 2308
My bias is to use lights that don't have the potential to shine in the direction of the screen, that is why on the front side of a riser I like the louver design. On the side it is a different story.
post #1289 of 2308
+1, I had to change my front riser light cover to a louvre one as it was reflecting off the hardwood floor onto the screen.
post #1290 of 2308
I wouldn't want that either. It still needs to be bright enough though to actually have a function. They are just too dim as-is. Trial and error I guess!
