AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The "Bacon Race" Theater / Patio / Bar Project
The "Bacon Race" Theater / Patio / Bar Project - Page 44
post #1291 of 2305
Quick "Leftovers"
I have 3 pieces of 2" thick OC703 at 2' x 4'
I have 17 pieces of 1" thick 3lb dense cotton at 2' x 4'
I have 7 pieces of 2" thick 3lb dense cotton at 2' x 4'
I also have about 17 feet (give or take a couple of feet) of the red "Claret Accent" GOM on a spool.
If anyone is interested in any of my old materials, let me know. Local Pickup is preferred due to size. My car wasn't made to fit boxes like that in.
post #1292 of 2305
Quick "Leftovers"
I'm interested if you don't get any local takers, thanks.
post #1293 of 2305
Here is an example of building a wall!
BEFORE:
Now the top black panel is inserted...
Another Angle
I don't see any electrical outlets along the walls. Are there any?
post #1294 of 2305
Quick "Leftovers"
PM sent
post #1295 of 2305
Sides of columns, usually on the side you can't easily see. Front wall behind the screen wall, Front of riser. Plenty. Most of the wiring was done inside the room and traveled around the room inside the soffits minimizing wall penetrations.
here is a pic of the front column.
post #1296 of 2305
Thanks. So, no electrical boxes where you have fabric covered walls?
post #1297 of 2305
in this case but there is an example of an outlet on a 1 inch thick fabric wall on the Black Cat theater thread. You build a furring frame surrounding the outlet, staple the fabric, cut a hole for the receptacle, You need to pull the receptacle out flush with extra long screws, The cover plate covers the staples. Make sure you know how big it is and where you can staple.
post #1298 of 2305
What if the panel is two inches thick? I couldn't find a 2" extender
post #1299 of 2305
Stack two one inch extenders and get some very long screws.
post #1300 of 2305
That works. If you already have a gang box in the wall pre-panel then that is really the only choice you have. For my light switches, I still had access to the back of the wall. There are lots of choices then. You can cut the hole and use an adjustable gangbox, which lets you make the depth above the drywall to begin with. So that also gives leeway. This is something we did discuss from the beginning, since we knew things like this would be a problem. In fact, we considered 2" treatments early on. So we were talking about how we would hang the door, how the knob and hinges would work, how the light switches would work. Planning is everything. If you think about stuff like that early on, then it can't surprise you later. I was fortunate to have BIG to ping all of these questions off of, and hopefully threads like these help others in the future when they do similar things.
As for all of the recepticles...yeah, what BIG said. Every column has one on the side. The point being, they aren't attractive and I didn't want them noticed. Two pair behind the screen wall, one on the riser too. The two rear columns had both on the insides, so easy to plug in the couches there without the cords being visible in the room. Worked out well too when I put those back vornado tower fans on the front corners of the stage since the cords pluged into the side of the front columns that face the stage.
post #1301 of 2305
How did you fasten the fiberglass panel to the drywall?
post #1302 of 2305
On this project the 2 inch fiberglass panels were friction fit in the wood frames, the details are in the thread. On other projects it is attached to the wall with drywall screws, but on the last job I tried a new screw and it really worked well. Some guys use 3M spray glue, I tend not to like working in the fumes. You really don't need a lot of holding power because if you do the fabric right it does all the holding.
The new screw I tried is the Power Head from Fast Cap. For two inches of material you should order the 3 inch. Use 6-8 for a 48 x96 inch piece of Linacoustic/fiberglass.
http://www.mcfeelys.com/product/0830...Cabinet-Screws
post #1303 of 2305
That seems like a good idea. I have posted a few questions on my thread. Would. Appreciate any insights. Thanks
post #1304 of 2305
As far as the acoustic plan, here is the last copy I sent. The only difference here is that we changed the side wall acoustical treatments to 1" and the rear wall 4". This is what Bryan wanted to do, but I told him I would rather not do 4" in the back... which I changed my mind on in the end, and am very happy I did so.
What is your speaker configuration? Are the ones outside the room simulating reflections?
post #1305 of 2305
It's a standard 7.2 setup. Front 3 and 2 subs behind the screen wall, 4 rear (2 rear / 2 side) inside the columns. If you are looking at the plan picture, yes, that's how bpape shows the reflections. There are no actual speakers outside of the room.
post #1306 of 2305
So here was the first panel we created today. If you would like to see how we do the fabric process, here it is.
Step one. Align one the fabric up on one corner of the panel and staple.
Then pull the far corner (lengthwise) tight, but make sure the seam is even along the frame so that the fibers aren't wonky, and staple!
Line up the center of that side with the edge of the fabric to make sure it is straight and throw a staple there to hold it in place.
Then you can just quickly staple that entire side along the edge.
So these black panels are not absorptive as called for in the plans?
post #1307 of 2305
Finally we put up all of the friction-fit screenwall panels and the screen frame.
Looks like your front surrounds are closer to the screen than the front row and not inline it and listeners' ears. Or is it a purely ornamental column (no speakers)?
post #1308 of 2305
This is only true for that very skinny panel at the very top of the wall . After the frame there really wan't much room left for absorption.
post #1309 of 2305
The side surrounds are slightly behind the front row. Front columns are ornamental
post #1310 of 2305
COLUMN BUILDING DETAILS
Recalling an earlier post the columns were inspired by Sandman's original round columns. So the question was without buying half round plywood forms like Ruben, what could we do to create some roundness and strong horizontal lines like Ruben's grooves.
Here is the idea Damelon and I came up with:
A three part column with rounded out trim above and below the speaker area. The speaker area will covered with black GOM FR701.
I built a prototype of the round out area to test the look and materials
Damelon said go
First up was a cutting a bunch of wood for the square box parts. Just 4 sided boxes, no internal bracing necessary, all butt joints.
Then we needed to add a rounded bump out so I needed a bunch of round pieces.
I built a jig to do this.
Mounted a jig saw on a scrap piece of Pergo with double sided carpet seam tape.
I calculated that the radius should be 29.75 inches to get the amount of curve over a 18 inch width. So the distance from the blade to the screw pivot point is 29.75.
Then I mounted the Pergo swing arm on a little Jig
It had a shelf to rest the MDF to be cut
And I cut 36 of these guys
The round outs on the columns consist of three of these pieces glued and nailed to the face of the square column faces. Then I covered the three supports with a piece of wall paneling. It is that faux wood paneling they sell at HD cut into 6 inch strips and just used upside down. The backs actually have a nice smooth finish.
Then I added matching pieces on the sides, you can almost see in this picture:
If you look you can see the base of the column that sits on and off the riser. Had to make the base of those columns at three levels to fit.
Next I needed the bump out trim bits. I wanted something about 3/8 x 1 1/4. Of course there wasn't anything on the shelf that size so I cut down 1x2s to size. I used Tuf Board that they sell at HD. I think it is a mixture of PVC and wood dust. An 8 foot length is like a wet noodle, at 18 inches sometimes you have to use and extra finish nail or two to hold it tight until the glue dries.
I also had to round over the edges
did that with a router table
a little bit later I had enough
cut some pieces to the right length and the right miters
glued and screwed to the fronts, used a spacer for the middle trim
added the sides. Then repeat for the 108 trim pieces.
column at the riser front
The middle section was detailed earlier in the thread, http://www.avsforum.com/avs-vb/showt...1#post20949031 I just need to add that we did fill the metal support members with dry sand. Plugged the bottom end with a wad of insulation and sealed the bottom with black silicon seal, let dry, then Damelon poured in about two cups of sand and we topped off the last 1/2 inch with silicon seal.
full size column
column at the back of the theater
Now I need to fill the nail holes, do some wood putty work, sand, seal, sand, prime and paint.
This is awesome! Did you fill the box cavities with fiberglass?
post #1311 of 2305
Yes.
post #1312 of 2305
Hey Damelon
Are your front columns pre-wired for anything? or purely symmetrical aesthetics?
post #1313 of 2305
Hey Damelon
Just power (for outlets) no speakers. It's purely for uniformity. It would seem unbalanced to me if there was nothing there.
If there was some future need to add speakers there, it wouldn't be hard. The hardest part would be prying out the middle column section (They are in there tight) but running additional wire down the soffit wouldn't be very difficult.
post #1314 of 2305
I cannot wait to hear how great a movie played through my speakers will sound once all of the room treatments and the carpet are finished.
So, how do ou rate the experience?
post #1315 of 2305
There are wall designs that just involve putting furring on the wall and stapling the fabric to the furring, no pre assembly of frames required.
Any reason that you decided not to use one of these wall designs? Where can one find these? Thanks
post #1316 of 2305
My theater, The Ohio project, The black cat all in my signature, Also search for CurtisG's theater http://www.avsforum.com/avs-vb/showt...light=36+month (Your Neighbor), ChinaDogs theater, and my original inspiration theater http://home.comcast.net/~kirkk/uptownparadiso.html
Be aware that there are a number of tricks to hide the staples and often a critical sequence of putting the strips and fabric on the wall, it will take some research and study to understand.
post #1317 of 2305
OK, took all the assembled frames and put on the beveled edge with a table saw.
This picture will make a lot of table saw safety gurus cringe, It made my saw cringe.
One order of frames to go, hold the bevel on two.
If the width of the plywood is 1-1/2", then in the final assembly there must be a 3" gap at least between the fiberglass? Is that the minimum gap one could safely achieve?
post #1318 of 2305
it wasn't safety it was minimum width before the panels would bend under the tension of the fabric. This was it. Even at this width we ended up inserting some bracing on a lot of panels. Your results may vary. You may want to consider the fabricmate.com plastic track system. Get two inch track and mount it on two inch furring.
post #1319 of 2305
Both Audio and Video wise, I absolutely love my theater. I am thrilled with my projector choice. It is absolutely stunning. Sharp, Bright, and excellent color. Far and away better than my wife's old AE3000, and better than my old Mitsubishi projector.
Sound wise, it's exactly what I expected it to be. Audio is crystal clear, and vocals are easy to understand. I hear no echos at all. I can play a movie at volume levels I like (Loud) and everything comes through with shining colors.
I still need to fix my subs, they both have faulty volume knobs on their amps, which Axiom told me happened to a few batches and will fix them. I keep forgetting to do it.
post #1320 of 2305
They are going to be black but first a coat of primer. I will do another coat turning the swivels the opposite direction. I'm under the deck in case it starts to rain again. Hmm, I see a spot I missed. Mosquitoes STAY AWAY DO NOT LAND HERE!
Hey Big, I'm going to attempt to do this this weekend. Did you sand these down before priming them or is that what the primer is for?
Thanks in advance,
Shadez
