AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Power extension cords
post #1 of 3
Guys
I could not find a place to put this and hoping someone here knows the answer
Does anybody know of any extension cords that show the live power usage similar to how kill-a-watt does it? I thought I'd see one in the past
If you don't know, can you please recommend a good extension cord with maybe 2 outputs at the end? Many of the ones I see have very thick cables and not looking for that
post #2 of 3
There is a kill-a-watt power strip, but yeah, does that thick cord.
post #3 of 3
I've plugged power strips into my kill a watt to see how much wattage my HT uses. (~90 standby, highest peak i have seen was ~490 watts. Sub not included.) Would that work?
A little more detail: I have 18" power cord, kill a watt, then power strip. This way it doesn't block the recep and I can see the display...
  Back to Forum: Tweaks and Do-It-Yourself
