About 4 months ago I bought a couple of popular subwoofers, at different budget levels, out of my own pocket in order to test them out and see what they bring to the table. The smallest and least expensive subwoofer is the one we will be looking at here, the Bic Acoustech PL-200.
This subwoofer can be commonly purchased web direct for around $269 to $289 depending on where you buy it from and what sort of sale is currently going on. This has been a very popular entry level sub that gets recommended a lot to people with a limited budget over the last couple of years. The subwoofer is a ported design utilizing a single back firing 4 flared port and a front firing 12 driver. The amplifier is rated at 250w, but a lot of the literature boasts of 1000w dynamic peak power. The amplifier is a BASH design. The enclosure measures 17.25 H x 14.75 W x 19.5 D and the whole deal weighs in at 52lbs, though it felt much lighter than that to me. I would personally consider this a compact subwoofer, but that sort of thing is subjective and depends on your perspective. Someone else may think it is quite large. The warranty is generous with 8years on the driver and 2 years on the electronics. I was impressed with the fit and finish on this subwoofer in light of the cost. Everything was put together solidly and the contoured gloss black top and bottom look very sharp contrasted with the black oak sides and back. The cloth covered grill is solid and locks in very securely with high quality fasteners.
The driver has a goldish colored plastic or painted paper cone (Couldn't tell for sure) and a very large foam half roll surround that looks imposing from the front. Pulling the driver from the cabinet and investigating the business end of it shows it to be less so. The motor is a very small single slug ferrite motor with what appears to be a 1.5 voice coil. And a single moderate sized spider. The back plate is very heavily bumped to prevent bottoming of the driver which is no doubt one functional aspect of the huge foam surround as well. There is no shorting circuit in the motor judging from the economy of the driver and the measurements, which we will get to later. Overall a very light weight and low cost driver, but this is not unexpected in this price range as larger, more powerful motors cost money.
The amplifier sports the usual rudimentary powered subwoofer controls: Speaker level ins and outs with a high pass crossover, input gain control, phase, crossover frequency and an LFE input which bypasses the crossover. There is no user adjustable EQ, automatic EQ, or room compensation which would be surprising given the price of the unit.
