AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Official Onkyo TX-NR1009 Thread
The Official Onkyo TX-NR1009 Thread - Page 12
post #331 of 343
Originally Posted by DCblackhole View Post
Yes everything works as it should. You just have to unplug every HDMI device from the receiver before you power cycle. I don't think the rest of the steps (resets) are actually necessary. Tech support walked me through the process of the hard reset without telling me I should disconnect everything connected to the HDMI board.
thanks, it didn't work. i unplugged everything but main1 hdmi out to the tv and turned everything on. then unplugged all the power again. when i pressed the tv power the onkyo turned on. the receiver even says tv/cd like it should just no sound. I'm suspecting now that my hdmi in the wall is v1.3.
post #332 of 343
Not sure if this will help anyone but my receiver is fairly finicky(buggy) as well and sometimes i will not hear any audio from source( TV-for example) after turning both on...what i found that works (but its a pain) is to cycle the TV "input" source from TV to HDMI (Onkyo receiver) and back to TV...I then get the over the air DDigital 5.1 audio back....only once or twice have i had to shut everything off and restart to get it to work correctly.Note: I connected a digital audio cable from TV to the Onkyo and this also eliminated the no audio from TV, BUT, this totally defeats the purpose of using a single cable(HDMI-ARC)....:-(
post #333 of 343
Looks like my hdmi board has bit the dust. I have been having intermittent problems over the last few weeks where I was needing to power cycle the receiver in order to get audio through my hdmi inputs. Well today, it has stopped working completely. I called support earlier and they suggested a firmware update and a factory reset. I did that and the receiver was working for a little while. Turned it off and came back to it a few hours later, no audio at all through the hdmi inputs.
Time to go in for service. I am sending an email off to the parts department to find out if there is anything they can do since the unit is only six months out of warranty .
post #334 of 343
Thats bad luck the HDMI boards are the only thing that concern me with Onkyo kit, hope you get a fix
Just a daft thought its not maybe a HDMI cable fault
Allan
post #335 of 343
Allan
I'll find out for sure when I swap my old 606 back in.
post #336 of 343
606 worked fine the with all the same cables and components. Bad 1009. Hope onkyo comes through on the out of warranty repair.
post #337 of 343
Fingers crossed not sure how well they do out of warranty
Allan
post #338 of 343
Anyone get a 929 in place of the 1009?
Looking at the 929 specifically for the bluetooth capability...
post #339 of 343
Allan
Thanks - must have worked. Onkyo came through and is taking care of the work. Dropped the unit off this morning and should be a week or two to get it back.
post #340 of 343
I would be thinking about it a little harder if it had Airplay support, really wish they had that built in. One nice thing is that unlike the 1009 the 929 does support a powered zone 2 and 7.1 in the main room since it had 9 channels. The 1009 has 9 channels as well but you can only use 5.1 in the main room if you want powered zone 2. Or you could run 5.1 plus front wide/high and powered zone 2. I am still bitter about that one...
post #341 of 343
Sorry this is like 3 months late... But you have to disconnect all of the HDMI cables. Meaning every single one of them. I made them same mistake of leaving the main out connected and that was the cause of hours of frustration.
post #342 of 343
Hi folks
Well yesterday i took delivery of the Onkyo 3010 and will be selling my loved 1009 really enjoyed it but XT32 was a big pull for me
Allan
post #343 of 343
This what i like about Onkyo they may have failures but they do seem to take care of you when things go wrong hope you have it back soon
Allan
