AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › NANO LG LV9500 Official Owner's thread
NANO LG LV9500 Official Owner's thread - Page 15
post #421 of 1697
Originally Posted by Slickman View Post
I can't see the blacks through all the blooming.
Might be time to upgrade your computer monitor, the photos only as good as the monitor. There was no visable blooming on the set or on the shot on my monitor. All full-array sets have blooming from the off angle. I printed the photo and used half the black ink cartridge.
post #422 of 1697
Originally Posted by JKTS View Post
I have the LW9500 and cant get AG-s250 glasses to sync. I followed you process, something must be different! What firmware you on?
Can you please post pictures of your EZ tool options?
Also, I would like to point out that you dont actually have to run the in-stop command THIS IS FALSE to enable 3d processing. Just turn you TV off/on after you make the EZ changes... I did run the instop though just for good measure. It did nothing though.
Please do not spread false information, my 3D is working and you are telling me you do not need the In-Stop. If you do not use the In-stop the 3D menu will show up and all it will do is make the image brighter, it will not make it 3D.
If you want your 3D to work, please follow the instructions. I have a W panel a the software update that was available when I turned the set on.
I turned on all 3D features (3) total including THX. I also went back and added the THX full function, it did no hurt the 3D at least after I had it added and functioning.
I want to help everyone obtain 3D, lets stick with the process that works.
post #423 of 1697
Rare you see someone posting screens of Baraka for visual quality, Kudos!
post #424 of 1697
Nothing wrong with my monitor, and another poster commented that he can see it too. It's very very obvious in that picture with the food.
post #425 of 1697
Please post pics of all of your tool options, instart & ezadj menus, and system1/system2 values.
Oz: Note that the tool option defaults for the LW9500-TA are listed in the service manual that I linked to.
-nony
post #426 of 1697
-nony
This is all I have accessed and my current settings. Not sure what in-start or ezadj menus are.
post #427 of 1697
Here are the rest, if you need anything else let me know.
post #428 of 1697
Please do not spread false information....
Dude - I'm not spreading false info.
When I enabled the 3d options, the 3D menu did come up (as you say) and all it did was turn everything bright (as you say) but when I switched off/on my tv, the TV started processing 3D (as I said) but I did run the in-stop for good measure (as I said). If it does work without running IN-Stop, it may save people grief in re-doing all their settings again. Either way, it dosnt hurt swtching your TV off/on after you make your EZ Adjustments and testing........
Anyhow, apreciate your efforts with the pictures. I'll compare with mine and see what the difference is.
post #429 of 1697
No problem, I just want everyone who wants 3D to have it. I tried without entering In-stop (for those who do not know in-stop is a button on your remote) and could not get the 3D to work. Let me know when you get the 3D working.
post #430 of 1697
I also had to run the InStop command - as originally suggested by nony early in this thread - before the picture would actually be processed. As you said, the picture would brighten, but no image processing would take place. It ran like this for a couple of weeks with multiple power cycles and it wasn't until I ran that command that it actually worked.
Maybe you got lucky??
What's interesting though is that you also have the LW9500 (as I do) but can't get the glasses to sync either. Do you happen to know what your part code is? It's located on the rear of the screen a big LG sticker with the model, product code and serial number.
Mine is 55LW9500-TA.AAUWLH.
There has been lots of talk about W and Y panels and how some do and don't have the 3D hardware, but as nony has mentioned a number of times - ALL panels support it.
I'm just wondering if there is some hardware difference between the LW9500 and LV9500
post #431 of 1697
Can someone put the exact instructions on how turn on 3D on the 55LV9500 with the use of a service remote. I am going to get one
Since I don,t currently have one. I was able to get to service screen with the magic wand and remote but, I need service remote to make
Any changes. Found place on line for 42 bucks plus shipping I don't want to screw this up !!
Thanks for everyone's help
post #432 of 1697
My Service Code is 55LV9500-UA.AUSWLHR it is an August 2011 build.
post #433 of 1697
I didnt get lucky - mine does and I have the same as yours. TA.AAUWLH...
I'm at work now so I cant compare my ez options with Videkid, but I did compare with yours - which is same as mine....
Differences are:
Tool 1: Tool "LW95".....................Videkid = "LV95"
Tool 2: Video & Audio ADC "11"......Videkid = "1" on both
Tool 3: Digital Eye = "0"................Videkid="1"
Energy Start = "off" ...................Videkid="on"
Tool 4: Different Digital demod and audio amp
Tool 5: Chanel browser = "1"...........Videkid = "0"
CNET = "0".................................Videkid = "1"
Tool 6 : N/a
I dont see how any of these would prevent glasses from synchronising.
I think we need to compare the In-Start options aswell.
post #434 of 1697
Issue the InStart command to get to its main screen and cursor over to System1 and System2 to access these child screens. See the 1st three screenshots that arkasi55 provided in the link below -
http://www.avsforum.com/avs-vb/showp...&postcount=157
Don't forget to block out your serial number before posting.
Also - Please turn off your set and remove the AC cord for about for two minutes, reconnect, and then confirm that everything is working ok.
tia,
-nony
post #435 of 1697
Differences are:
Tool 6 : N/a
You never know what dependencies have been put in the code.
Param changes:
1. Are activated immediately
2. Require a recycle to/from standby or
3. A complete power down or
4. An explicit command to save to NVRAM as a config default.
There are no glaringly obvious hard rules.
-nony
post #436 of 1697
-nony
I quote from the user manual under 3D Imaging
"Energy Saving is disabled while playing in 3D."
In Tool 3, the Energy Star option has a difference between the LW and the LV. Possibly a dependancy ?|? - I'll may test tonight.....
post #437 of 1697
Sorry, but especially on the first and the last shot the blooming is obvious.
The food comes from Jesus himself appearently and the Fox News-Blue shines into the shoulder of the poor man.
post #438 of 1697
can w panels get 3d? and how? CAN ANYONE PUT IT TOGETHER ON ONE POST AND LET THE REST OF US IN ON 3D.I HAVE A W PANEL AND WILL SEND IT BACK IF ONLY THE Y PANELS HAVE 3D
post #439 of 1697
Not going to get into the blooming debate with trolls, whatever you think is ok with me.
Back to the 3D of these sets. I think I found the issue, its the glasses. The 3D glasses and my set both have a AUS in them. The glasses have a AG-S250/AUS on the side of the box. I believe you must have an AUS in your service code number for them to work.
This does not mean there is no a pair of glasses for you sets, just not the
AG-s250's.
I am playing with Monster universals, I do not think they will work but will keep you posted.
post #440 of 1697
Not having any luck with my glasses. When it syncs it seems to blow up the picture and everything is doubled figures, top and bottom. May even be the Sammy 3D blu ray player?
post #441 of 1697
Do you have a AUS in your service code on the back of the set? Attached is the box my glassed came in, the last three letters match the letters on the back of my TV sets service code.
post #442 of 1697
Have you tried testing it with 2D -> 3D on the local set first?
post #443 of 1697
Please see my post below, I have 3D working on my "W" set.
post #444 of 1697
Yes, they match yours.
post #445 of 1697
Trolling? I analyzed your pictures with Irfan View and I'm just disappointed by halos. Sorry.
post #446 of 1697
videkid...are u in the US?...if so, where did u get ur glasses? thx
post #447 of 1697
I sent you a PM with my nuumber if you would like to discuss what you have going. I will try and help you out.
post #448 of 1697
See Below
post #449 of 1697
Then spend 5 times more a purchase the Pioneer/Elite (Sharp). I see no blooming while watching regular content and for the money I paid have no complaints. If you have some positive input I would love to see some more post from you. 480KZ full backlit 1080P 3D set for $1,500 is enough to keep me smiling.
post #450 of 1697
.... I think I found the issue, its the glasses. The 3D glasses and my set both have a AUS in them. The glasses have a AG-S250/AUS on the side of the box. I believe you must have an AUS in your service code number for them to work.
AG-s250's.
Mine is the AG-S250.AL. This dose not match my set :-(
Intresting to see if those Monster universals work.
