Originally Posted by
Nighthog
I do wonder if there is a gamma issue between choosing 16 or 19 as the black.
Generally changing a brightness control doesn't significantly affect 'display gamma', or how the display changes light output near 'display black' (darkest possible shade). The first video level above 'display black' will typically be produced at the same light output difference, regardless of the brightness setting. Say you have two scenarios:
1) The first video level above 'display black' is 17.
2) The first video level above 'display black' is 20.
Most digital displays will have the same light output in #1 for 17 that it will have in #2 for 20.
This is generally what the DVE test is based around. The video black background from the DVE standard pluge is 16 and the first level above video black is 20. By aiming for a subjective difference between 16 and 20 their instructions essentially open the door for 17, 18, 19, or 20 to be the first level above 'display black'. They're generally aiming for a low setting, so things such as the display performance near black, room lighting, and viewing distance determine where 'display black' actually falls below video level 20. Most other commercial calibration patterns for setting brightness use a lower first video level above video black, rather than the 20 used in DVE. With typical viewing distances and room lighting, generally a changing video level is easier to spot than a static difference, so often flashing 16-19 appears about as easy to notice as a static 16-20.
Here are some possible reasons why setting 'display black' at video black (16) may not be subjectively similar to the DVE instructions:
- 'Display black' is not very dark
- First levels above display black are a significant change from 'display black' (very low gamma near 'display black')
- Very dark room, or little room lighting
- Short viewing distance
I reckon many here who prefer 19 could try a lower gamma point in the lower parts with 16 instead. (Presuming you can adjust gamma in the detail needed to adjust the lowest gray scale points only.)
Yes, for most of the people carrying on the discussion it would be preferable if the display could come out of 'display black' more slowly. Generally it would be ideal if 'display black' was set at video black (16) and the electronics could be adjusted to come out of black at various rates to account for most of the items mentioned above. Assuming a display had this much control, in the prior scenarios #1 & #2 then video level 20 could have the same light output difference above video level 16, regardless if 17-19 were displayed or cut off.
