I am trying to set up my system so that I can close the doors and still use a remote. I have a new Pioneer vsx-52 and a Motorola DVC box from Comcast. I noticed both have a socket labeled "IR in", so I ordered two of these from Monoprice:
I plugged one into the cable box, and one into the Pioneer. It works great with the cable box, but not with the Pioneer. I also tried plugging it into the control S jack, but that did not work either.
I have been searcing everywhere, and get conflicting info. ome of this is because Pioneer has both a IR in, and a Control S in, which are different.
Does anyone know where I can get details on what the IR in jack on the Pioneer is expecting?
I'd like to know:
* Is it a mono or stereo jack?
* How is it wired. Does the signal go to the tip or the ring?
* Does the jack supply power, or do I need a device with a separate power supply?
* Is it grounded, or do I need a separate ground like the Control S jack?
* should the signal be modulated or un-modulated? If modulated,, at what carrier frequency?
* Is it a 5v signal?
* Or is here just some setting I need to switch in the unit to turn the jack on?
With this info, I can find a device I know will work.
I'd like to know:
