AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Yamaha BD-A1010 Universal Player
Yamaha BD-A1010 Universal Player - Page 7
post #181 of 322
Definitly agree with the reviewer on the video side. The audio from the analog outs is nite and day difference. The yammy "Blows away" the 93. Real close to the 95 in fact
post #182 of 322
Really? Bummer for me. I really want one of these for that function (audio playback) but was turned off by comments about video quality.
post #183 of 322
Unless you have a lot of SD DVDs to watch, the video side of things are doing just fine on A1010.
post #184 of 322
If your receiver or display use Marvell, Anchor Bay, Faroudja, HQV, Silicon Optic's Relta, etc., when playing an SD DVD, set the 1010 to 480i and let your receiver or display do all the video processing. Then when you're ready to watch a Blu-ray again, remember to set the 1010 back to 1080p so you can take advantage of the disc's image quality. Of course, if Yamaha adds something like "Native," "Original," "Source Direct," etc., you wouldn't have to manually switch resolutions back and forth all the time.
post #185 of 322
This reminds me of hack reports for the Seiki BD660, the HP BD2000, and the Philips BDP3000. It shows the region code. I am able to format all the internal memory and reset the password, but I can't change the BD or DVD regions. Is there some hidden trick to highlighting and/or changing the DVD and/or BD region codes?
post #186 of 322
I though the A1010 had a 'Pure Direct' switch that included disabling all video processing? Or is that setting only for audio?
post #187 of 322
That's not exactly what that means in this case, as well as on other players. Pure Direct in this case means turning off all outputs except analog and HDMI. Supposedly this reduces interferance from other circuits not being used. I'm not sure if I believe in this form of interferance filtering. I haven't noticed a difference on any player yet.
post #188 of 322
I just picked up a Yamaha BD-A1010 and it's my first player that supports BD-Live. I popped in a disc and selected BD-Live and it said that this feature requires local storage. Yamaha requires 2GB or greater. I'm wondering what the max is that I would realistically need. Should I buy a 4 GB drive? 8? 16? I have no idea how much space is preferable, if the content is deleted once you've viewed it, etc. Also, if speed, transfer rate, etc., is important, I'd like to know that, too.
Many thanks,
John
post #189 of 322
I'm trying to enable my BD-A1010 to stream from Netflix. I go to "HOME" and choose the Netflix icon. The player gives me a code to enter on the Netflix "Activate" web page so I run to my PC, enter the code, hit "Activate", receive the message "You are ready to watch instantly. Go check it out now!", I run back to the TV and get the message "password has expired, try again" or something like that.
I've tried it five times and get the same message everytime.
Anythoughts on what else I can try?
I can't run any faster.
post #190 of 322
Just got my BD-A1010. Is there a way to set it up to be region-free? I have a few PAL DVDs I'd like to play...
post #191 of 322
Hi - I recently received a new (b-stock) BD-A1010 from Yamaha. I got this as part of there trade in/repair program. The init looks perfect cosmetically and seemed to be working fine. However, I've had a couple of issues I can't resolve and I could really use some help determining if these are typical with this unit, if there is a way to resolve them, or if I have a lemon.
First, I downloaded the iPhone AV Controller app. It works fine with my new Yamaha receiver - discovered it automatically. However, it does not find the Blu-ray player. I tried entering in the IP address manually, given the info in the BD-A1010's setup screen, and, after several tries, if found it, then, a few days later I tried the app again, and the player was not listed and now it will not find it, no matter what I do. When I click on the Network Connection Test, on the player, it says "Network is OK" and I BD live seems to work fine, but still the app still can't find the player.
The other issue I'm having is that I put it a brand new Blu-ray of "Some Like it Hot" and I got the loading "spinny wheel", then the 20th Century Fox splash screen animation with music, then the FBI warning screen, then... nothing. I took out the disc and re-inserted it, still nothing. Tried powering the player off and back on... still nothing. Then, suddenly, after several attempts, I got the movie to play - once. It played all the way through, and since then I have not been able to get it to play - at all. The machine just stops and the front display reads 1:1:00:00:00.
I'm not sure if this is a problem with the disc or the player. I called Fox to see if they would send me a replacement disc, and they told me that, since the movie played once, then the problem is not the disc, and that I needed to clear out the cache on the player. Since there is no setting to do this, they suggested I call Yamaha. I'm now waiting for a call back from a level 2 tech, since the level 1 tech couldn't help me with either of these issues.
Do I have a bad player? A bad disc? Why isn't the app discovering my BD player when it has no trouble finding the matching receiver? Is there a way to clear the cache? Perform a factory reset?
I'd greatly appreciate any help I can get.
Many thanks,
John
post #192 of 322
From my disks I have one that locks up the player. A DVD, Region Code: 0. Europa-Konzert from Lisbon w/Boulez, cond. and Pires, Piano. Better than instructions in owner's manual, I simply press and hold the power button in until the message "reset" than release the power button and push the eject. This to me is more convenient than unplugging the unit. This has been my only troublesome disk so far. Just from curiosity, I wonder if anyone else have had any problem disks.
post #193 of 322
I have one bad disc - "Some Like it Hot". It's an MGM/Fox Blu-ray (U.S.). When I put it on, it will play the Fox intro, then the FBI warning, then...nothing. I took the disc to Best Buy and tried it on three different BD players and it worked perfectly each time. Yesterday I received a replacement player (b stock) from Yamaha and had the exact same behavior as the original unit.
The other issue I'm having with both the original and replacement units is that the Yamaha A/V controller iPhone app won't discover the BD player. It will, however, find my Yamaha receiver.
When I originally contacted Yamaha, they said both the iPhone app and the "SLIH" BD disc should have worked, so they sent me a replacement player. It will be interesting to hear what the say on Monday when I tell them about the replacement player.
If anyone has any thoughts regarding these issues, I'd really appreciate some feedback.
John
post #194 of 322
The motor in my replacement 1010 seems especially loud. I can hear it throughout the movie. Is this typical? I don't recall my original unit being this loud. Both units are "B" stock.
post #195 of 322
I got my A1010 yesterday and was playing some CDs and SACDs. It's hooked up to an Onkyo AV receiver. I noticed that when I turn it on, pop in a disc and start playing, if the TV isn't on, no sound comes out. The Yamaha thinks it's doing something since the time display is chugging along. If I turn on the TV I get the sound from the AV receiver after a couple of fits and starts (almost as if the receiver tries to figure out the audio format).
Anyone else seen this?
post #196 of 322
Hi JSULMEYER,
I have exactly the same issue as you with trying to connect to the BD-A1010 via Ipad or Iphone.
Had a connection once,now cannot connect even though I can connect/control my AV receiver with no issues. I can Ping the IP address and the BlueRay says the connection is OK.
Has any one else come across this issue and resolved.
post #197 of 322
I really wanted this player but now after reading about some issues here, I won't be getting this player. That sucks cause it would've looked great next to my RX-A2010.
post #198 of 322
What issues? My unit has been perfect so far.
post #199 of 322
You're a lucky one.
I had three different units, and everytime the motor drive was noisy.
and not a liitle.
So I sent my last unit to yamaha support who changed the drive for a new one.
Noisy again.
It's really annoying, since the player is really the best I've tried (above the last Pioneer & Oppo)
So now I have to send it back to yamaha, and hope they'll fix this issue.
post #200 of 322
I have no idea that I'm the lucky one, or not.
I have an all-Yamaha setup(receiver, all speakers minus the subwoofer, BD player, SACD player with the matching int amp), also on my 3rd Yamaha receiver, all of them have been running without any problems.
I always think that Yamaha is one of the leading brands when it comes to quality and reliability products. (biased thoughts?)
post #201 of 322
(biased thoughts?)
No you're right.
Reliability is the word to describes YAMAHA.
Except this time, they don't use a yamaha drive in their player, but a Panasonic.
And I can't think Reliablity when it's about Panasonic.
post #202 of 322
Originally Posted by Frenshprince View Post
(biased thoughts?)
No you're right.
Oh, I'm fully aware that A1010 is based on someone else's design(in this case - Inkel), but I never knew about the Panasonic BD drive until you mentioned it.
Well anyway, good luck with your replacement unit.
post #203 of 322
Hi I have one of these on order. I hope it works out well given the issues I have been reading about. I cannot find any firmware updates on the Yammy site for this puppy. Do they not post them. I went to the URL in the manual http://download.yamaha.com/downloads/service/top/
?site=europe.yamaha.com&language=en
but that only yielded the manual again. I do have a couple wireless gaming adapters that I can use with it to get it online, but was hoping to just update it with disc or USB stick.
Also, is the player discontinued? According to Crutchfield it is, but not on the Yammy site. I seem to always buy the stuff that is discontinued and no more f/w updates come out. Have 5 Sammy DB-UP5000s HD/BD combos, an LG-BH200 BD/HD combo and a Tosh a35 HD player in the fleet along with an older Sammy SACD/DVD-Audio player that this is retiring.
Good thing that Crutchfield has a 60 day return policy and it has a full warranty in case I run into any of the hardware issues that you guys have.
BTW - what is the latest code and how long ago was it updated?
post #204 of 322
Along the way on my A/V journey, as many of you know, I can hear a difference when eliminating audio jitter via HDMI. However, at this time, the options to do so aren't 100% perfect. I looked at some integrated BD player/receiver units, but the Sonys lack options for speaker sizes and speaker selection, and the Yamaha BD-RX610 lacks SACD support. Now I'm glad I hung on to my 2006-model Yamaha HTR-5935SL receiver, included with the YHT-370 package, because of its 5.1-channel analog input. Before I go through the trouble of bringing my Pioneer Elite VSX-32 receiver up to my bedroom and bringing my Yamaha HTR-5935SL back down to my livingroom, when playing the multi-channel layer of an SACD via analog on the BD-A1010, will the frequency response reach 100 KHz when the HDMI audio is turned off and SACD output is set to DSD? I know the AK4358 DAC in the 1010 is capable of the 50 KHz cutoff, but that doesn't always mean it is being used. Some of the older Denon universal SD players had an option for switching the top of the SACD playback frequency response between 50 KHz and 100 KHz.
Edited by Big C - 6/23/12 at 5:32am
post #205 of 322
Hello,
I just bought a brand new BD-A1010. At first I noticed when playing a few discs that have PIP and secondary audio tracks that the little PIP / audio icons would pop up and stay on the screen indefinitely when it reached a point in the film where those options were available. Having seen this before, I went into the setup, and turned off all the markers under "playback".
Now, the PIP icon still pops up CONSTANTLY throughout the entire move then goes away about 2 seconds later. This is highly distracting. Specifically, the popping up constantly happened throughout the entire James Bond "Casino Royale" blu-ray. I noticed the first problem on "The Matrix" before I disabled all the markers.
There does not appear to be any firmware updates yet. Anybody else having this annoying problem and know how to fix?
post #206 of 322
Originally Posted by joey_corleone View Post
Hello,
I don't get mine until next Monday and I haven't checked the manual, but several of the HDP players I have owned have a setting called something like "turn screen messages off" or "suppress messages" etc. I sometimes have to select that with my Sammy 5K to get them to go away, except they actually fixed that problem a few firmwares ago, so it is only very rarely and mostly when I regress back to older f/w to play things that for some reason or another don't play on newer firmware.
Reading this thread and seeing these issues makes me wonder if I made a bad choice with this player? If nothing else it will be a good replacement for my long in the tooth Sammy SACD.DVD-Audio player and I might have to keep the Sammy 5Ks around for DVD upscaling and the like. I was planning on keeping it anyway since I am a pack rat.
No firmware updates, really? Been out over 7 months and no updates. WTF is up with that. Does it seem ok playing newer releases? That kinda blows my mind. Either the code was very well written, or they just don't care about keeping it up to date?
post #207 of 322
I got nowhere when I phoned Yamaha technical support on this matter. I didn't think I would because this question is more appropriate for the engineers. I know my belief in reproducing frequencies up to 100 KHz for DSD playback is annoying people here at AVS. So here's my calculated guess (and it's only a guess) after some serious thinking. I am going to assume that any manufacturor who allows DSD to be converted to 176.4 KHz believes in the higher frequency response of SACD playback. So therefore, when the 1010 converts DSD straight to analog, the manufacturor chose not to use the 50 KHz cutoff filter. Besides, a while back, someone gave an opinion that the 1010's analog sound is almost as good as the Oppo BDP95, which according to Oppo uses the 50 KHz cutoff when converting DSD straight to analog, and when converting DSD to PCM, it only does so at 88.2 KHz. While the 1010 may lack a little in the video department, it's looking better for audio as those thoughts and posts keep coming!
post #208 of 322
I compared the analog outputs of my working SACD players, and the Yamaha BD-A1010 provides the deep lows and ringing highs I've been after. So now, except for my TV, everything in my system (the speakers, receiver, and subwoofer) are all Yamaha. Getting specific, my main system now consists of a Toshiba 32E200U TV, a Yamaha HTR-5935SL A/V receiver, the Yamaha NS-AP5700BLF speakers (each with a 6.5" woofer and a 0.75" tweeter), a Yamaha SW-P3600 nonpowered 10" subwoofer, and the Yamaha BD-A1010 Blu-ray player connected via analog to the HTR-5935SL A/V receiver. I have decided that I don't need gamma anymore because even if I set it so everything looks right when using the THX facilities, some colors not included with those facilities are distorted. So unless there's a serious problem, I leave brightness, contrast, gamma, hue, and croma level in the nutral position. Now my only problem is playing discs from other regions on the 1010. I've tried hacks for other Mediatek players such as Philips, HP, JVC, and Seiki. None of them work. Will those Oppo region-free kits work on the 1010? I've also tried copying the disc using AnyDVDHD, but I'm afraid of using the five-change limit on my laptop's RPC2 drive, even though AnyDVDHD was advertized to bipass software and hardware region encryption. If anyone has any ideas regarding the player, decryption, or both, please post them!
post #209 of 322
I've read all kinds of things about Yamaha BD-A1010, but at the end I'm still confused. When playing SACD, does Yamaha BD-A1010 convert the signal to PCM and then to analog, or does it convert the signal coming off from SACD directly to analog without the conversion to PCM?
post #210 of 322
Apparently, the manual states that with HDMI audio off and SACD>HDMI output is set to DSD, speaker configuration settings are ignored during SACD playback. This is a sign that the DSD is being converted directly to analog. In order for speaker configurations to function during SACD playback, the SACD>HDMI output must be set to PCM. Yamaha should have named the DSD/PCM setting "Playback Mode" instead of "HDMI Output" because whether using analog audio or HDMI audio, the setting I am talking about switches the player between DSD and PCM. As I said before, this player's analog output has the best SACD audio quality out of all the universal players I've used throughout the past eight years of my A/V journey.
