Originally Posted by mikepaul
I'm not sure I should stay on the course I've been sailing. It's fairly easy to just level up, with some places still giving plenty of XP even though the enemy level is 6 below mine now that I'm at 29-1/2. However, not advancing the story is leaving Sanctuary handing out equipment at least 7 levels lower than me. Some other places are OK, but they don't have the number of machines that Sanctuary has. I could seriously use 4,000+ shields but they are nowhere to be found. Haven't been to Opportunity yet though.
Did find an E-tech rocket launcher, which, when I use it on enemies, produces a bluish bubble where they used to be. The double-shot perk kicks in sometimes but they don't follow each other. The fact that it does far less damage than the blue one I have makes it less desirable than it could be, but it's amusing...
You're not going to get a shield that has 4,000 damage protection until you get to L33 - L34 and/or somewhere near the end of the game. Even then, it's going to be a standard Turtle Shield, so don't think you're going to have 4K protection AND it's going to absorb ammo PLUS drop boosters while ALSO producing a huge nuclear blast every time it takes even the slightest damage. Opportunity isn't the peaceful place you likely think it is either, although if the enemies are levels lower than you, it may as well be.
My question is how are you even getting damaged when the enemies are 6 levels below you? At that point, you should be nearly able to walk up and punch badasses in the face and be done with it, let alone be worried about finding or using an obsolete weapon or shield that's 7 levels lower than your current one; regardless of color, race, or religious status of said gun. This makes no sense to me. When I was trying to get my 750 shotgun kills at close range for the Open Wide challenge, I would just waltz through a parade of baddies 5-10 levels below me, racking up numbers at will. It's like these guys couldn't wait to die...like strangling a kid at Camp Sleepyhollow with a cordless phone easy. I simply don't see why you would "need" a 4K shield for that.
Maybe I'm dense, but I'm still not getting why you're having difficulty.
