I have have started my hushbox project to silence or at least tame my LP340. The spec says 37dB, but I get 50 to 51 dB from 3 feet away sitting directly beneath it. It's finally gotten to me, and so here is my design.
I started by reviewing other member's hush boxes and gathering ideas from the resulting discussions. Next I created a poster board and wooden dowel mockup to understand the aesthetic impact on my living room ceiling. Next I drafted a model of my design in AutoCAD in preparation for building it. This past weekend, I got with a buddy and made the box out of Lexan. I still need to install the foam baffles, install the cooling fan(s), mount the box, and cover the box. I will be adding to this thread as I complete this project.
I bought a digital thermometer from RatShack to see how hot the exhaust was and to get a baseline temp. Ambient was 76 F, running was around 104 F. When I held the box over the projector, with the intake grill on, and no other holes, the temp rose to about 113 F rather quickly so I knew exhaust fans would be needed. But, the noise drop was very noticeable. The high pitched and very annoying whine was gone, so the box is going in no matter what obstacles :)
My original plan was to use a 80MM case fan to exhaust into the floor space above the projector. But I found a very promising product I think will be better. A 5.25 hard drive cooler call JustCooler TT900 from www.2cooltek.com has two 90MM fans pulling almost 80CFM at 26dB. The main exhaust fan on the LP340 is 16CFM at 27.8 dB. For $18, if it doesn't work out, then I have a PC that could use it. I also ordered SONEXmini polyester foam from the same dealer. 16"x24"x1" sheet is $9.00 so I got two. I'll update you when I get them installed.
As for the box itself, I had originally planned to paint it flat white to match the ceiling, and maybe even spray popcorn texture on it. But my wife suggested we cover it with the same velvet fabric we used on our DIY screen frame. So that's the new plan. My mom has volunteered to sew it up for me, I'll post pictures when it's ready.
Well, that's it for now....fire away :)
Here is the link to the photos thus far: Jaydmdigital Webshots
Jay
Jay
