Philip,
I will take a shot at you questions....
Originally Posted by
pmcd
@500GB
Do the ZVOX units sound different if the TV is not sitting on them? For example, could they be on a shelf under the TV (the TV is living on a stand with 2 glass shelves under it).
Where you position it will change the way it sounds. High end is very directional, so the further away it is from "ear-shot", the less you will hear. Since bass is omni-directional, positioning matters less. Also, bass can be amplified a bit if it is say, put in a cabinet. It can use the cabinet as a resonator. So.... positioning is very important when it comes to soundbars.
Some soundbars depend on back walls to bounce signals to create faux surround-sound.
pmcd
When you connect the 580 to the TV via optical are any sounds lost?
Theoretically, if the signal is digital, optical cable shouldn't loose anything (anyone, please correct me if I am wrong here....).
pmcd
How do these units comprehensive with a Bose Cinemate system?
I haven't heard the Cinemate in my house, but have heard it as a demo. IMO, the BOSE sounds much better. A big draw with ZVOX is simplicity and it has its trade-offs. It will greatly improve your TVs sound, but it won't give you "big" surround sound or even great stereo. It is not for audiophiles, but for people who want a seamless almost "hidden" system and better sound than most TV speakers are capable of giving.
pmcd
Is optical better than analogue?
I have used both with my system and I thought that optical sounded a little stronger, but it may have been psychological. I had to go between the two... I can tell you that I don't think there is a huge difference.
pmcd
Philip
